"Found it" (I think)
Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By WRB
Thread: "Found it" (I think)
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Default "Found it" (I think)
    The emulsion tube that was completely undone in my carb is related to the first barrel and it is easy to see how this would let more petrol through. The first barrel is completely covered in black loose soot. The second barrel however, looks brand new and, there is a reason for that - the butterfly was jammed shut - I have fixed it so, who knows, I may have much better acceleration.
    Just waiting for the rebuild kit and I will know for certain that it is fixed.
    pug206gti and Armidillo like this.
    Armidale
    2,540
    We had an "L" series Subaru wagon with a twin-throat carbie. Power felt fine on small throttle openings - fine for pottering around town at low revs - but it just had no "oomph" at higher speeds. Climbing hills was embarassing! Plenty of compression (good low rev performance showed that), spark checked out OK, carbie appeared to be clean with no blocked jets.
    Problem was eventually found to be a blockage in the vacuum tube that operated butterfly in the 2nd throat of the carbie! Once that was cleared the ol' girl went like a bird .
    Amazing how often "serious" problems have simple solutions - hope you really are on top of this one!
    Alec
    16,695
    it might pay to strip it down and check it. The blue ID19 here had what was obviously an expert rebuild its carby. He/she did a lovely job, rheemed out and fitted a new throttle spindle etc.... And it ran like a pile of merde.... I eventually pulled the carby back down and found the throttle butterfly had been fitted backwards. It's slightly offset, this meant the idle was no good, and it would stick in the bore when the throttle closed.
    It's always the simple things that catch you out
    10,090
    Similar story with a D Special I spent some time with. The basic adjustment of the linkages on the carby was all wrong. A different car after eliminating the bend on the base and simply following the factory instructions on setting it up.
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Just got a can of cleaner so, it is all coming apart and getting brought back to new. i have done a lot of these - mostly on Hillmans and BMW bikes.
    Oct 2011
    Toowoomba
    650
    Webbers on CX - the internal plugs go walkies and you can't set the idle properly. Killed 2 so far.
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    The internal plugs are tiny!
