DS23 ie fuel mix
Results 1 to 15 of 15
    Fellow Frogger! IE23's Avatar
    Jan 2011
    749
    Default DS23 ie fuel mix
    How do I adjust the fuel mix? I believe it is running lean.
    I know about the ECU adjustment but is there another adjustment possible on the intake manifold? I'm looking at the screw adjuster but this is for idle revs only?
    Adrian
    _________________
    Current;
    Xantia V6 Exclusive Auto 2000
    Past;
    CX25 GTI Turbo series 1 1985
    DS23 IE Pallas 5sp 1974
    CX25ie Pallas Auto 1984 Parts
    2CV 1988
    Member Mitchell's Avatar
    Perth
    105
    The potentiometer on the ECU will adjust mixture - at idle only (when activated by contacts in the throttle switch).
    The coolant temp switch (T2) is critical in providing inputs to the ECU, that will impact on mixture. Worth changing just to be sure. These are the same as on any Djet water cooled car.
    One work-around is disconnecting the ambient air sensor (T1). This will richen the mixture by around 20%
    After the simple things, the likely candidate for mixture abnormalities is the MAP sensor (or pressure sensor).
    Rhys
    16,702
    low fuel pressure could cause issues, I can't remember if we can check the manifold pressure sensor with Djet. Oh, if you check TS2 as suggested (the most important check), drop down the ECU and do it at it's plug. This was you are testing the wiring to the sender as well.
    1000+ Posts pottsy's Avatar
    Melbourne, Northern Suburbs
    1,099
    When I was the proud owner of a DS23 ie I created a fuel pressure gauge out of an oil pressure gauge, a t-piece and a bit of tubing.
    I fitted it on the fuel line leading up to the cold start injector and was surprised to find that my car was in fact running a bit lean. By bringing it up to the nominal figure the running improved immensely.
    From memory the optimum fuel pressure is 28psi, and the fuel pressure regulator is adjustable so one can achieve this. By adjusting the fuel pressure you are effectively changing the "float level" to create an analogy with carbies, if that makes it easier to understand?
    The potentiometer control on the "ECU" is only a fine adjustment of the idle mixture. Like all idle mix adjustments it has little or no effect when the throttle is open more than a bit.
    Hope this helps, Pottsy.
    Buvito Ergo Sum!
    The Fleet:
    2018 C3 Shine ("Oscar" Mrs P's) Grandma's Taxi
    1974 D Special Manual Sedan ("Moby Dick") Weekend Warrior
    2015 C4 Grand Picasso ("Pablo") Workhorse & Grandpa's Taxi
    1982 2CV6 ("Gaston") Seasoned Traveller
    1975 GS Pallas ("GiSelle") Shrunken CX
    Jan 2011
    749
    This feed back is marvellous!
    i removed the TS1 sensor and instant improvement. I have also added octane booster to my fuel which I suspect has become stale plus topped up with 98. Doing this has eliminated the pinging.
    where is the TS2 located?
    how do I adjust the pressure regulator?
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
    Jan 2011
    749
    The pressure regulator is sealed. I replaced this with a NOS recently. So my next step is TS2, once you tell me where it is.
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,045
    Does disconnecting the air temp sensor also increase the richness of the mixture at idle speed?
    1,099
    Quote Originally Posted by IE23 View Post
    Interesting. I thought all the injected D's had the adjustable unit. Ah well, you can still measure it with a gauge anyway, just not do anything about it!
    Cheers, Pottsy
    Buvito Ergo Sum!
    The Fleet:
    Perth
    105
    Citroen D-jets utilise a type 1 manifold sensor (the simplest kind), they are adjustable via a slotted screw, after the epoxy potting is removed. Very sensitive and best left alone if you don't know what you are doing. Buying a NOS unit was a great move. Buying any NOS D-jet components for future use, would be good too.
    I've never had a I.E. D, so don't know where T2 lives. Can't be hard to find it...looks similar to T1 with the same electrical connector - mounted in a water jacket somewhere. Last one I got was $44 + GST (trade)
    Rhys
    Jan 2011
    749
    Found the TS2 location. Ordered a NOS replacement from eBay.
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
    Kapunda
    493
    Hi Adrian,I too have never seen a non adjustable Fuel Pressure Regulator.The temp sensor(not switch) at the front inlet side of the head can be easily checked with an ohmmeter.I have a facility for checking the MAP sensor.
    Woody
    North Brisbane
    2,045
    Woody,
    How are you checking the MAP sensor?
    Cheers, Ken
    Kapunda
    493
    Hi Ken I have a complete EFI system wired up on the Bench with an electronic box to simulate the Dissy plus a hand vacuum pump for Manifold pressure.This way I can check injector pulse widths through the whole operating range So I can check any component.W hile I dont have any official figures ,I use the average results from components that I know work well.
    Woody
    16,702
    There is one temperature sender just behind the water pump (from memory) the other is on the air cleaner. I've read in the past unplugging the air cleaner temp sender will make the mixture slightly richer.
    I'd whip the calculator out and replace the capacitors too. Mine wouldn't run when I got it due to dead capacitors in the calculator. It's an easy repair as it is all standard electronic components available from ebay/electronics stores
    I can't find the pdf of the Djet manual, but here is the html version:
    http://shanescitshed.com/ds21fuelinj/index.html
    Jan 2011
    749
    thanks Shane, I have this in PDF and was reading it further yesterday.
    Interestingly with the air temp sensor removed the engine performs nicely. Fortunately I have two ECU's and so far they both perform the same. One was tested a few years ago. Anyway I have more investigating to do to resolve the cause.
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
