2004 C5 2.0 HDI serpentine belt replacement
    Jan 2016
    5
    Default 2004 C5 2.0 HDI serpentine belt replacement
    Hi Guys,
    I just replaced my dodgy alternator and all went well until I've gone to replace the serpentine/accessory belt.
    I think I missed the bit about placing a drill bit/bolt to keep the tension off to allow refitting.
    However I figure it's the same situation you might have if the belt snapped altogether so while annoyed at being a goose I am hoping it's not terminal?
    I have access to the Haynes manual but it's an electronic copy so a little hard to search through.
    Thanks in advance.
    Don't remind me!
    16,609
    It may be worth consulting YouTube - don't overlook French videos for "courroie accessoires" too.
    Dec 2010
    canberra
    167
    I am not sure about the C5 but Xantias with spring loaded tensioners have a hex head or a hex socket (can't remember which) to allow you to take the tension off the belt when replacing it. Have a close look at the tensioner, you may be able to use a spanner to wind it back.
    Regards
    agd123
    Jan 2016
    5
    Thanks,
    I worked it all out with a bit of trial and error and belt fitted with no Battery Charge warning - yay!
    Tension comes off the same way whether there is a belt or not.
    Now I just have to find my multimeter and ensure that the replacement part is working okay but the engine management system was pretty quick to tell me when something was wrong :-0
