Checking LDS in C5 X7
    Auckland, NZ
    68
    Default Checking LDS in C5 X7
    Ok, I thought this would be as straight forward as it was to check in all the other Citroens that I've owned but now I'm not so sure?
    After a search in the web I read that the LDS level should be checked with the suspension in 'normal' ride height, and engine turned off. Ok, I did that and proceeded to loosen the lid on the tank and was met with a great hiss of air pressure escaping (at least I think it was escaping; could have been sucking from vacuum?). Lid was quickly screwed back on, and here I am!
    Is this normal, or have I left out a step somewhere? I assumed that it would have a had a breather cap on the tank?
    8,159
    Quote Originally Posted by cresco750 View Post
    I've no experience with the X7, but with the early cars the level is checked with suspension on LOW. Level should be around the centre seam on the reservoir.
    08 C5 X7 HDi very Noir
    Auckland, NZ
    68
    Yes exactly, hence my confusion :-). My tank is black so I'm unable to see any level without removing the cap. I'm expecting to find some sort of strainer with an index mark when I do?
    8,159
    Try setting the suspension to LOW, this should de-pressurise the system allowing the removal of the cap. I don't believe there is a level indicator, just a case of peering in and ensuring the level sits around halfway up the reservoir.
    8,589
    In the handbook link I sent - Le contrôle du niveau de fluide LDS s'effectue véhicule en position basse forcée, à l'aide de l'outil de diagnostic
    The a and b level marks in the cap filter are shown.
