1972 Citroen DS / 5 speed manual .....Gearbox and Differential oil ?
Results 1 to 7 of 7
Like Tree5Likes
  • 1 Post By badabec
  • 2 Post By Citroenfan
  • 1 Post By Citroenfan
  • 1 Post By brycedunn
Thread: 1972 Citroen DS / 5 speed manual .....Gearbox and Differential oil ?
    Oct 2015
    england
    20
    Default 1972 Citroen DS / 5 speed manual .....Gearbox and Differential oil ?
    Ok, I would like to give my DS some fresh gearbox oil, but the 'Brooklands ' manual that i have, is confusing the hell out of me.
    Quote; .................................................. .................................................. ...............................
    " The oil recommended by citroen is total ATF 33 and the amount required to fill the unit is 10 and a half pints ( 6 litres )
    Measurement is made by means of a dipstick which is held in the filling tube, on the front right hand side.
    The dipstick for the differential gear oil is also on the right hand side behind the radiator. This is marked mini-max, and the oil specified is SAE 80 EP " .................................................. ........... Unquote.
    Well I cant find a filler tube or a dipstick for the life of me
    And can I not fill both the gearbox and the diff, from the same place.... with the same oil ?
    Any help greatly appreciated.
    Feb 2012
    Ongar / England
    811
    Hello, you'll find two drain plugs. One for the 5th gear housing and one for the main gearbox. You need to drain both. There is a level plug on the side of the gearbox. You can refill it through there or through the filler plug on top of the gearbox. I gained access by undoing the radiator shroud and pulling it forwards, then filled till it came out of the level hole. It will fill both the main and 5th speed housing.
    I used EP75-90 as that was on the shelf. The first lot that came out was very much like oxtail soup. I refilled and re-drained after 2-300 miles and then added an additive as well.
    Whilst the drain plugs were out I fitted each one with a magnet to catch any (magnetic) swarf.
    The new oil certainly made a difference.
    You'll need a decent sized oil collection pan, not for the volume, just that you'll have two holes dripping at once, although one, of course, will be down your arm.
    Peter
    Roger Wilkinson likes this.
    Symar/ca/usa
    607
    Quote Originally Posted by gavinmlane View Post
    The 'Brooklands" manual info you are reading is for the B/W 3 speed automatic unit - not a 4/5speed manual tranny What you need is a high quality 80/90wt GL5 manual gearbox lub. The 5 speed boxes need 2.25 liters to fill. You check level by removing the side mounted nut - fill to the point where gear lub just starts to come out of the opening.
    While I am not at all a fan of 'additives' I will just mentioned that some on this list have recommended the use in the manual boxes of Nulon G70 manual gear box and diff treatment - and these are owners whose opinions I do respect
    Steve
    Roger Wilkinson and denxm like this.
    Oct 2015
    england
    20
    Excellent, so no diff oil and no dipsticks.... except me
    Thank you badabec and thank you citroenfan.. most helpful
    Fellow Frogger! brycedunn's Avatar
    Jun 2012
    165
    Quote Originally Posted by Citroenfan View Post
    I would just add that GL4 would be a better choice than GL5. GL5 lubricants are for modern cars and can attack brass components in older transmissions.
    1954 Light 15
    1970 DS21 BVH
    http://www.classicjalopy.com
    Symar/ca/usa
    607
    Quote Originally Posted by brycedunn View Post
    Sorry about the mistype - I did mean GL-4. However I would still recommend the addition of the Nulon G70 additive. Have been using it for some time now - about 80,000 + miles on my 72 BVH and the tranny shifts fast and smoooothly. No problems downshifting - even into 1st gear at speeds I should not have
    Steve
    UFO likes this.
    Jun 2012
    165
    Steve
    I also find the nulon additive to be good. I think quite a few people on this forum use it.
    Bryce
    UFO likes this.
    1954 Light 15
    1970 DS21 BVH
