xantia windows
  • 1 Post By Ken W
Thread: xantia windows
    Nov 2014
    ashburton nz
    25
    Default xantia windows
    hi guys has anyone got a fix for xantia electric windows ;drivers side window stopped working
    then the other three stopped going but now they are working again but not drivers side ;had no luck searching
    archives has anyone had same problem
    regards kevie.
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,892
    I always search via Google - here is a cut and paste from google results.
    Thread: Xantia window regulator - Aussiefrogs
    Jan 11, 2011 - 25 posts - ‎10 authors
    Hello all I am seeking some advice regarding the replacement of the window regulator for a Xantia drivers door window. I have offered to ...
    Thread: Xantia window failure - aussiefrogs
    18 Sep 2013
    Xantia door window regulator - plastic clips - Turkey ...
    1 post
    4 Feb 2013
    "modified" window regulator - Xantia mk2
    15 Sep 2011
    Cables of window regulator - Xantia Mk2
    10 Sep 2011
    More results from aussiefrogs.com - French Car enthusiasts site for Australia Since 1999 - Citroen Peugeot Renault - aussiefrogs.com & Froggy Forum!
    JohnW likes this.
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    Are the windows all closed? From your description it sounds like it. In that case check the normal electrics, fuses but there is a large multi pin plug in the passenger footwell that forms part of the circuit. Ours needed some work as water leaked in and corroded some of the connections. Remove the passenger carpet and it will be under a plastic cover.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    Armidale
    2,282
    The back windows in my Series II Xantia will go down, then refuse to come up! Usually fixed by switching ignition off & back on, but they seem to need a rest before they will work again. That footwell connector might be a good place to start, so thanks for the tip Greg!
    Alec
    Nov 2014
    ashburton nz
    25
    thanks guys still working through these links
    all the best kevie.
