Cooling Fans staying on - 07 C4 Hdi
Results 1 to 9 of 9
    May 2012
    Warrnambool
    63
    Default Cooling Fans staying on - 07 C4 Hdi
    Noticed recently the cooling fans have been staying on after a drive, sometimes up to 15 minutes after.
    It isnt hot around here, maybe 22 at most, fully serviced and fresh coolant a month or so ago.
    I understand that it may need to cool itself, thats fine, but when i can walk out to the car an hour after driving it and then the fan kicks in again when i open the door, i think something maybe up.
    Any ideas or suggestions as to what could be going on?
    Car is a 07 C4 Hatch 1.6 Hdi Manual.
    sorrento
    98
    We had same issue it was fan heat sensor switch
    9,777
    Could be either the coolant temp sensor or the fan control unit in a box on the radiator support panel. I think the latter is likely if they keep running from memory and I presume this is what bobsie means. Anyway, take it out and see if you can see anything visibly wrong with it. I have a vague memory of thinking it was somehow repairable if you could buy the thermal switch (small disc type as I recall) in the circuit, but replacement is probably safest.
    May 2012
    Warrnambool
    63
    Would going through a car wash effect it at all?
    9,777
    Shouldn't. Could be coincidence, but would high pressure water have reached the control unit on the radiator support?
    May 2012
    Warrnambool
    63
    Not really sure. Wouldnt have thought so but maybe? Are they on the engine side of the support or the outer?
    9,777
    Ahead of the radiator and to the left from memory. Small black plastic box.
    San Diego, California, USA
    3,534
    And check your battery. I know that sounds odd, but on a car with a CANBUS system (almost everything built today) the voltage levels are extremely important, at rest or running. A battery that's just a little naff can cause some really weird problems. Ensure the terminals are corrosion free.
    May 2012
    Warrnambool
    63
    Must have just been the car wash somehow. Was fine the next day and since.
    Ill keep an eye out next car wash too
