DS recovery
Results 1 to 14 of 14
Like Tree6Likes
  • 3 Post By IE23
  • 1 Post By David S
  • 2 Post By IE23
Thread: DS recovery
    Fellow Frogger! IE23's Avatar
    Jan 2011
    749
    Default DS recovery
    It's a slow recovery from bastardisation by a well know mechanic who shall not be name for legal reasons.
    The good news is my beloved DS has been in the hands of a real professional mechanic for several months and is well on track for perfection again.
    In addition to rectifying the mistakes made by the idiot, I have had the fuel tank reconditioned, inside and out. The tank was cut in two and sand blasted then welded and painted.
    Adrian
    _________________
    Current;
    Xantia V6 Exclusive Auto 2000
    Past;
    CX25 GTI Turbo series 1 1985
    DS23 IE Pallas 5sp 1974
    CX25ie Pallas Auto 1984 Parts
    2CV 1988
    Ici.
    2,560
    those straps have a vinyl layer under them ; ) and get some caulking agent around the filler pipe outside on the rear frame, stop the leaky leaky rustyland.
    16,423
    So what was wrong with it
    seeya
    Jan 2011
    749
    seeya
    The tank had a lining that was delaminating, flaking paint clogging up the filters and stopping fuel flow . When the tank was opened rust was also evident.
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    I think I know that mechanic....
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,234
    Russ Neversleeps?
    John
    Member Pommiefrog's Avatar
    Jul 2005
    England
    85
    I wish my tank was salvageable/repaired like yours. I opted for a new tank and sadly the pick up is too short, it means I start sucking up air way too early before the tank is empty. This in theory means having to fill up more frequently even when there may be more then 20 litres of fuel in the tank... There's a lot to be said for original parts and repairing them if possible before going for reproduction.
    Much more to do on the recovery?
    George
    Leicestershire, England
    1971 DS21 EFI, Pallas, BVH, Blog:http://www.mypallas.net
    8,184
    Quote Originally Posted by Pommiefrog View Post
    Hi George,
    Is it not possible to extend the pick-up with some rislan/nylon tubing?
    08 C5 X7 HDi very Noir
    Jul 2005
    England
    85
    Hi Chris, that could be possible, I will need to take off the sender and see how easy it is to fit my arm down the hole and get to it, from memory thought the hole is fairly narrow. Another thing on the 'to do' list...
    George
    9,774
    The old tank would have had the plastic pickup tube rammed right down the metal tube inside and to the bottom of the tank. The metal tubing seem to act only as a guide. You'd want to seal it with a clamped rubber hose sleeve. The internal baffles will mean you can't get at it via the sender hole.
    ... and back to IE23. Previously you claimed the car ran very poorly after extensive work and even suspected a compression issue. What has changed to resolve that? Was it an EFI issue? Others might benefit from your experience and the corrective action required.
    UFO likes this.
    Jan 2011
    749
    Grrrrrr!!!
    Petrol in and the tank is leaking! not happy Jan.
    You would think that a specialist tank repairer would properly test the tank after completion. He told me he tested it with air, "but air doesn't always find the leaks whereas petrol will". OK so if he knows this then he is taking a risk of handing over a leaky tank and in my mind that is not good enough!
    The tank has to come out again........!!
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
    9,774
    ... and now you also have the added hassle of dealing with 60+ litres of petrol before taking out the tank!
    16,423
    The CX will make short work of 60litres on fuel
    Jan 2011
    749
    Boyracer and petermelb like this.
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
