Cx sub-frame
Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By WRB
  • 1 Post By addo
Thread: Cx sub-frame
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Default Cx sub-frame
    Thought Cx owners might find these interesting. From the 818-2 manual....
    addo likes this.
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    The subframe can't take the weight of the power train resting on wheels alone, that is the purpose 6651T. For safeties sake I would remove the engine before removing the body like that.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    Don't remind me!
    16,609
    Look where the horizontal centre of mass is for the break! No wonder they are quite well-mannered.
    JohnW likes this.
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    I wouldn't do it with the engine in place, but having the suspension set up so that you could roll it under the body would be good.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,068
    Cx sub-frame-dsc01953.jpgCx sub-frame-dsc01954.jpgYou would need to raise the body shell quite high to achieve necessary clearance. If you have rafters in your garage it would be possible to winch it up that high. Ordinary jacks would not be enough. I found that even to get the sub frames out using jacks and stands I had to place blocks of wood on the jack head to get enough clearance. I made a trolley that was no more than 6 inches high and moved on two fixed wheels and two castor wheels. The frame of the trolley supported the whole Sub frame /chassis assembly.
    Cheers Gerry
    10,800
    I had nearly, but not completely forgotten that awesome work, not least the excellent photographs Gerry. Hope you are using and enjoying the CX.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Fellow Frogger! caparobertsan's Avatar
    May 2011
    SOUTH MORANG
    793
ID:	75438Click image for larger version.
ID:	75439You would need to raise the body shell quite high to achieve necessary clearance. If you have rafters in your garage it would be possible to winch it up that high. Ordinary jacks would not be enough. I found that even to get the sub frames out using jacks and stands I had to place blocks of wood on the jack head to get enough clearance. I made a trolley that was no more than 6 inches high and moved on two fixed wheels and two castor wheels. The frame of the trolley supported the whole Sub frame /chassis assembly.
    That is an amazing set up! Full resto yes? Very clean organized garage!
    1961 Citroen ID19(2010~), Holden Frontera(R.I.P 2002-2014), Honda Accord EURO(2006~)
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    I am amazed that you were able to do that by yourself Gerry! Takes a lot of commitment and focus (and an amazing memory as to where everything has to go)
    3,068
    The memory sometimes fails when it comes to "Now where did I put that"!
    Cheers Gerry
