DS ID Rubber chart LHM/LHS
Results 1 to 9 of 9
Like Tree6Likes
  • 4 Post By GreenBlood
  • 1 Post By Dave Rogers
  • 1 Post By David S
Thread: DS ID Rubber chart LHM/LHS
    8,250
    Icon6 DS ID Rubber chart LHM/LHS
    I cant remember where I found this, but thought it useful - rubber seals tubing etc. sizes, part numbers etc.
    Shame about the quality of scans but if you are rebuilding a rack, pump etc., it's all there. . .
    Shared PDF in my dropbox, get it while you can
    https://www.dropbox.com/sh/q9j43is1u...g0yrrN_4a?dl=0
    08 C5 X7 HDi very Noir
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,158
    That's Great Chris! Ta Muchly!
    Cheers Gerry
    San Diego, California, USA
    3,543
    Worth having a copy. Thanks Chris.
    Member wilrex's Avatar
    Oct 2014
    Buninyong
    79
    Thanks for the chart.
    I have a few problems in converting my ID19 1961 to LHM.
    Have changed most of the rubberware, but can not find a replacement for the suspension cylinder seals.
    it is fitted with the D434-94 oil seal lip type seals, but I can not find them for LHM on any of the supplier sites.
    I am sure someone has the answer.
    Also can not find the brake master cylinder plunger cup for LHM.
    Rex
    2CV6 Special Green, Riley RMB, RX7 Rotary, Jensen Healey, 1896 Ford A replica, and last but not least 1961 Citroen ID19-P... Previous include, 27 Chev Truck, 24 Bean Truck, 27 Chev Capitol, Rover S105, Humber Hawk x 2, MGB, Ford AA Truck, Ford A, elderly motorbikes x6, and more...
    Fellow Frogger! Dave Rogers's Avatar
    Frankston Melbourne Australia
    270
    Thanks Chris, from one Dropbox to another.
    GreenBlood likes this.
    83 2CV Charleston
    79 GSA
    01 Renault Scenic
    8,250
    Quote Originally Posted by wilrex View Post
    Rex
    Can you use suspension cylinders from a later car i.e. D Special etc,? It shouldn't be too difficult to find later replacements. I'm not sure what you would do about the brake master cylinder but be sure someone has gone down this path - maybe a specific question here in the Citroen forum will yield results. . .
    Don't remind me!
    16,609
    Bellissimo! Molte grazie!
    10,128
    Being a fairly early ID, isn't the brake system actually a regular brake system with its own fluid reservoir and a powered emergency stop booster? Wouldn't you consider converting to the later doseur valve system if you are going to the trouble of going to LHM? Using selected parts from a later ID19B/Special already on LHM might be the simplest way forward.
    p.s. A very useful upload Chris.
    Mar 2005
    920
    I did a similar mod to a 61 ID19 in my youth .. only without the LHM. Converting a 61 to later mushroom brakes isn't difficult but does involve a bit of extra non hydraulic stuff. The floor profile on a first nose car is different. Remember the exhaust pipes are central and the floor is centrally raised. The "gas" pedal is a high mounted pendant running a cable. Second noses are rod organ floor pivot. Brake light switch is different. Even if a donor car was a pedalo ( low square pedal )... what we would refer to as a "62 ... the floor and gas pedal are different from master cylinder cars. There was I recall a difference in the front disc brake piston diameter too. That car was always very front biased in braking, something the rear brakes and height corrector couldn't balance with. But after the heavy pedal pressures of the master cylinder car the braking power was immense, the car however would just try to bury its nose. far easier to retain the working master cylinder system and fit a vacuum booster. back in the day the family ran several IDs. The master cylinder 61 always had probs keeping a high master cyl pedal. We suspected at the time there was some sphere leakage that allowed gas into the "reserve/desperation" outer end of the master cylinder. I can't recall ever getting to the end of that .
