I tried to remove the coolant tank from my Series 2 Berlingo without success. I removed the nut from the front location point and was able pull the tank forward to remove it from the rear locating peg. However, the tank would not lift vertically due to a body member being in the way. I could not pull the tank forward as was restricted by the head lamp assembly.
It occurred to me that I may have to remove the right hand headlamp assembly but I decided against that.
Obviously there must be a way to remove the tank and I would appreciate someone telling me how to do it.
Thanks.
