Xantia 2.0L CT Turbo magic chips and black
  • 1 Post By alhantos
Thread: Xantia 2.0L CT Turbo magic chips and black
    78k
    78k is offline
    Gatton QLD
    21
    Default Xantia 2.0L CT Turbo magic chips and black
    Has anyone out there used any Xantia 2.0 CT Turbo chip reprogramming and black boxes that claim to increase performance?.
    Thanks in advance.
    brisbane
    2,925
    Why not just turn up the boost to 1 bar....that is the limit this setup will take comfortably without going to the next step of changing the exhaust manifold [available from Holland $800 ] and when doing that you might as well put a new T28rs on it.....for much more Grrr.
    I have this motor in a 205 and its running 150kw at a low .8 bar. With the original T25 it has boost from waaay early which is great :}
    jr20516v
    Now:
    Exige SC [modded], 205 Si. 205 GTi , Megane R26 LY , Megane 225 [modded ]
    Previous: Honda EP3 Supercharged , 205 x34 [ including MI16 TURBO, 8v TURBO, CTI, 16V+TB's, 8V+TB's,] Fiat X1-9 X3, Beta coupes x5, Lancia Gamma coupe, GTI-R, Corvette C4, Fiero x5, Alpine GTA turbo, r5 GTT Dimma, 2cv ripple nose, Lotus Elise, 205 Dimma TT, Cliosport 172.x2, Clio rs 200
    Armidale
    2,542
    Tell us more! Can the standard ECU be reprogrammed to do this, or do you have an aftermarket ECU? Or are you using manual wastegate control?
    Are you using the standard manifolds & injectors?
    (I also have a Turbo CT).
    Alec
    brisbane
    2,925
    yes, standard ECU, injectors and manifold. The ECU will handle a 1 bar boost....thats all though. After that you will need aftermarket ECU.
    Personally i am using all the above however i run Haltech in case i decide to go for further upgrades [always a good option to have ]
    jr20516v
    Now:
    Faulconbridge
    2,668
    Quote Originally Posted by jr20516v View Post
    Excuse my ignorance but how do you turn up the boost,Andy.
    Armidillo likes this.
    Don't remind me!
    16,609
    You can use a manual boost controller.
