Citroen D special with seized engine
Results 1 to 3 of 3
  • 1 Post By David S
Thread: Citroen D special with seized engine
    Jun 2012
    north fitzroy, victoria
    191
    Default Citroen D special with seized engine
    am trying to help a mate with a resurrection. No - not Tony Abbott.
    A 1975 D Special with a seized engine. Anyone got a good running spare?
    am in inner city Melbourne
    rewards could range from swaps for other Citroen things - Light 15 motor for instance - or bits from a very dead DS23 EFI - or money - or love - or whisky - or sacrifice of first born.....
    inquiries to [email protected]
    cheers
    jon
    10,094
    The engine is really a fairly simple unit and you will have to remove it regardless, so maybe pull it down and find out what's failed before going further? Was the oil filter cover fitted backwards and then starved of oil, was it overheated or has water entered and rusted it solid? It's a good opportunity to fit 21 liners and pistons and items like bearings are quite reasonably priced. If going for a donor engine, remember that a 23 auto engine has a different crank (plus other minor differences) and won't take the flywheel, although there's meant to be some adapter plate that can fix that.
    addo likes this.
    Ici.
    2,651
    The H frame should be reinforced at engine out as well, you can buy plates to bolt on. I understand the 23 motors put more strain on the frame? Causing stress/cracks/ sagging?
    Better to redo the motor than just swap over, least you'll know you've got a decent engine once rebuilt.
