CX Subframe
Results 1 to 8 of 8
Thread: CX Subframe
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Default CX Subframe
    I had a good look at the Subframe rails on the CX today. They have been bashed in just under the driver and passenger seats to the point where that are almost flattened. I really should replace these at some stage so, if anyone has a parts car that they wouldn't mind me tipping on its' side, please let me know (I promise to be gentle....)
    16,322
    post some piccies of what you need .....
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    It is the two longurinnnnnnnes (whatever there called) between the front and rear subframes - they really have been caved in. I will show you when I come up.....
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,020
    If you separate the sub frames from the longerons you will need to make up some sort of a jig to keep the front and rear sub frames properly aligned to each other. This is critical!
    Cheers Gerry
    Don't remind me!
    16,609
    I'm watching the list stack up of things that apparently need attention sooner than later. It's making for a disappointing perspective on what was hoped to be a good car.
    Could the car be dry stored, and a suitable "chassis" built up with all good bits and PAS etc, then the shell lifted onto it?
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    I am not to concerned, I won't attach the new subframe bits until I start the resto later next year. In the meantime, I intend driving it and repairing other bits as I go. Really only a few things that I hadn't expected and, that would probably be true of any 40yo car you buy....
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    Somebody jacked the car using from the 'chassis' B.....ard
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    No Greg because it is on both sides - looks like somebody went 4 wheel driving and slid over a rock
