CX instrument cluster
Results 1 to 15 of 15
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Default CX instrument cluster
    Hi ya,
    Are the warning light plug fixtures a standard part used in lots of other cars? I am missing 5 (including the oil and water temp lights)
    cheers
    Warren
    16,698
    I've seen the globes and bases at Sunday Markets, they are T5 globes from memory.
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,044
    You can often persuade the bulbs to come out of the holders and replace them. They are a standard item in the Navra range that Repco sells. Jaycar also sell a LED 12 volt globes in white, blue red green and yellow already fitted to the twist on bases but they only work in one orientation and are probably brighter than an original bulbs.
    Cheers, Ken
    16,698
    I've got plenty of blown globes/holders here if you need them. You'll just have to fit some replacement bulbs into them. If you haven't guessed I have plenty of spare CX bits .........
    seeya
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    I should pop up and see you. It would be a good way to give the car a run. Let me know if that would be okay and, if so, when would be the best time.
    cheers
    Warren
    16,698
    Of course it's ok .... Let me know if your coming in the XM ..... so I can make sure the car trailer has air in its tires and the rangey has a full tank of gas
    seeya
    Jun 2012
    87
    I have spares (old ones) if you find yourself short
    Melbourne, Victoria.
    1,390
    Hahahahaha Shane, that's GOLD.
    1,390
    Quote Originally Posted by WRB View Post
    Hi ya,
    cheers
    Warren
    That's not a good sign Warren. It sounds like the previous owner just removed the warning globes one by one as things broke down. The old blown globes should surely be there. I'd be taking the cluster right off and checking for all the missing globe holders. They shouldn't be MISSING. They should still be attached to the wires , hanging around somewhere under the instruments block. Just unscrew the speedo cable and remove the instruments, and have a good look around.
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Hi George,
    The holders twist into a circuit board and so, are not held in by wires so, they are gone (I did have a look around)
    cheers
    Warren
    I will be coming in the CX Shane so, you (and I) can rest easy....
    Fellow Frogger! John P's Avatar
    Somerville, Victoria
    153
    If Ballarat is too far for the XM, I have plenty of spares here too.
    2006 C5 2.0 HDI estate - daily driver
    1981 2CV - The Amelie project is complete.
    1930 C6F torpedo - My Great Folly! Project under way.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,155
    Quote Originally Posted by John P View Post
    Hey Guys, cut it out!!! Warren made it to the Bendigo run a couple of weeks ago with no trouble what so ever! A very fine looking XM. It impressed me!
    Cheers Gerry
    16,698
    I'm sure he realises we are just joking around.............. Of course I wouldn't go rescue the XM .... He might want me to work on it
    3,155
    I would not blame you for wanting to doge that bullet! I get the impression though that he is very capable of working on it himself!
    Cheers Gerry
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Come on Shane, you know you cannot resist a challenge:
    Reverse lights don't work;
    Car goes up and down at traffic lights (This is known in nautical terms as "Pig F**cking");
    Car cuts out about 2 minutes after starting it for the first thing in the and then is okay for the rest of the day;
    Starter solonoid - sticky
    gearbox solonoids - sticky
    seats - sticky ()
    Ya reckon you can have all that sorted by yesterday?
