CX Pictures....
Results 1 to 14 of 14
Like Tree9Likes
  • 7 Post By WRB
  • 1 Post By Greg C
  • 1 Post By JBN
Thread: CX Pictures....
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Default CX Pictures....
    :d
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,158
    That looks terrific Warren! Much better than my old girl when I first acquired her. Wow what an interior!
    Cheers Gerry
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Only one door card is warped - the rest are perfect. The new upholstery is the wrong colour but, I am not too fussed - I think it is better than the original striped colour you can just see on the door card. He didn't do the foam though and so, you do tend to sink into the seats a bit more than is comfortable. Still getting used to the manual box and the fact that, for real power, you can rev it out past 4K without getting anywhere near the red line. I was only going to 3K and wondering why it lacked power up hills.
    3,158
    Yes! They thrive on revs!
    You may be able to take the warp out once it is off the door. Pack the centre section and add weights around the periphery whilst applying some judicious warmth to the centre section. The backing is pressed board and it is the shrinking of the plastic coating that causes the warping. As it is a thermoplastic it should soften enough to stretch out under force of the weights. Just how much force is something you would need to experiment with!
    Cheers Gerry
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    Looks very nice. I think the seats look quite OK too. Better to concentrate on rust removal and getting the steering and clutch pedal working as per the book.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,474
    My memory is a bit dim, but I think the front seats have some rubber straps below(?) and on the backrest, As they stretch, so does the support for the foam. Otherwise, undoing the upholstery and adding some foam may do the trick.
    John
    Fellow Frogger! Middlemoon.1's Avatar
    Jan 2011
    Alphington
    859
    That is one classy car.
    Tim
    16,717
    That's a very nice looking car. The interior is simply amazing. I'd just get it sorted and enjoy! Those reflectors at the bottom of the front guards may have rust holes behind them (I can't think of any other reason for the reflector being put there), so it may pay to pour some oil down into that area
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    I intend to just drive it for the moment and sort what I can when I have time and money. I have been down to Frankston and back twice this weekend (for my daughter, who hasn't quite got the knack of public transport yet...) and I can say, for a car that is named after it's drag co-efficient, the wind noise is bloody loud ...
    Oct 2003
    1,304
    The rubber seals around the doors, also it does not have the flat rubber hanging from the bottom of the doors, They cut down a fair bit of wind noise. It was a standard fitment on Grande Exportation cars, yours probably is not, just a private import. CX Basis sell some additional rubber seals that fit into the doors and give a secondary seal for the doors. It made bit of difference in the Prestige.
    CX-BASIS :: eShop
    JohnW likes this.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    I have seen those seals on some other cars and so, will fit them to mine. To be fair, it was a really windy day today with lots of cross winds. I will also be doing the heat insulation installation that Shane did to his and, this will have a positive affect on road and engine noise. The air-conditioner needs re-commissioning and so it was also getting a tad hot inside - this is more important than the clutch given the imminent onset of sunny weather.
    3,158
    I deliberately removed those seals from the lower door edges. They are attached with small self tapping screws that introduce another potential rust point. In fact they are probably the major reason for most cases of CX door rust here in Australia. I know that I had a lot of work to do to clean up after their removal!
    Cheers Gerry
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    I thought the profile was a bit sus - the bottom edge of the door in a groove in the rubber would be a trap for water. I don't think that they would make much of a difference to wind noise. The extra rubber around the door would do a really good job though.
    JBN
    JBN is offline
    8,474
    The best thing I did to my CX was to replace all the door rubbers with replacement new ones. Easily done in the mid 80's when they were available.
    I removed the rubber flaps below the doors. Removed the aluminium scuff plates on the door sills (and rust underneath)and then injected fish oil into the floor sills. I coated the underneath of the scuff plates with under body seal before replacing them onto the sills.
    Rust never sleeps.
    John
    JohnW likes this.
