correct lds fluid level C5 2009
    Mar 2013
    israel
    71
    Default correct lds fluid level C5 2009
    hellow guys
    changed my c5 2004 with a c5 2009
    there is a black lds reservior (old one had a yellowish one....)
    i happen to remmember there is a different way to read the correct lds fluid level. am i wrong?
    what is the top level of lds fluid when suspension is on lowest settings?
    thank you all for answering.
    Mar 2013
    israel
    71
    anyone?
    10,093
    Same procedure as for the earlier C5. The gauge in the filler is meant for use when it's fully depressurised, for which you need the diagnostic tool. Instead, you'd place it to low and make sure it's approximately at the level of the seam in the tank. Harder with the black tank than the translucent tanks. Make sure the tank does not become bloated or it might split. It's meant to be under only several psi / 0.5Bar pressure.
    Mar 2013
    israel
    71
    no need to open the cover?
