DS Fuel Gauge as Temp Gauge
Like Tree3Likes
  • 1 Post By ds21bvh
  • 1 Post By mberry
  • 1 Post By wilrex
Thread: DS Fuel Gauge as Temp Gauge
    719
    Default DS Fuel Gauge as Temp Gauge
    An interesting link....
    I thought it was more complicated that that.... it seems that it can just be swapped over with a new decal.
    I wonder if you can buy the decal...?
    https://www.youtube.com/watch?v=BIY0DYOepso
    There are some other interesting links on rebuilding things by "DSSMPASSION CITROEN" - well worth a look around.
    Mark...
    Mort Subite likes this.
    Mar 2011
    Broom
    819
    Decals will set you back $2.00 postage, resetting the speedo at the same time, priceless!
    Fellow Frogger! Boyracer's Avatar
    Sydney South
    601
    I did this to my blue car about nine years. No decal though.
    As a gauge it's only indicative of course, but then so is the original.
    Michael
    ____________________________
    Citroen Car Club of NSW - Member
    1974 Citroen DS23 non Pallas BW Auto/Carby with Air-conditioning [AC640 Delta Blue]
    1972 Citroen DS21 5SPD EFI Pallas [AC088 Blanc Meije]
    2012 Citroen C5 Exclusive 3.0L Auto Diesel [Noir Perla Nera]
    Member wilrex's Avatar
    Oct 2014
    Buninyong
    79
    Talking about fuel gauges, I removed the sender from the tank of the ID19 to inspect it, and found that the internal flexible earth wire had been fractured over time and now had jagged ends that contacted each other when it bounced around in the tank. I repaired and replaced it, but it could have easily produced a spark inside the tank.
    Therefore, maybe if you have a gauge that is intermittent, it may be worthwhile to check out the sender internal earth wire.
    Rex
    2CV6 Special Green, Riley RMB, RX7 Rotary, Jensen Healey, 1896 Ford A replica, and last but not least 1961 Citroen ID19-P... Previous include, 27 Chev Truck, 24 Bean Truck, 27 Chev Capitol, Rover S105, Humber Hawk x 2, MGB, Ford AA Truck, Ford A, elderly motorbikes x6, and more...
