Grey rubber strip and spring that runs around the inside edge of roof?
Results 1 to 14 of 14
  • 1 Post By forumnoreason
Thread: Grey rubber strip and spring that runs around the inside edge of roof?
    Fellow Frogger! Lasya's Avatar
    Jan 2015
    A comfy place.
    319
    Default Grey rubber strip and spring that runs around the inside edge of roof?
    Someone mentioned in their thread about replacing this rubber strip after replacing the old 'spring' within it and replacing it onto the roof. I can't now find that thread. Could someone point me there or where can I get a new one? I've trawled Citroworld and Der Franzose with no luck. I'm sure I saw one before I decided I needed one.
    Gillian and Chris
    74 D Special, and now a 74 Pallas 23 5 speed with air(maybe). And now a Cactus!
    Oh, and a Holden.
    Lasya, Tibetan goddess of the moon and beauty who carries a mirror.
    8,159
    Quote Originally Posted by Lasya View Post
    GreenBlood’s D(very)Special Rejuvenation 2009>
    CITRO' SERVICES Srl
    I don't believe the metal clasp strip is available. . .
    08 C5 X7 HDi very Noir
    Jan 2015
    A comfy place.
    319
    That sucks, ours is rusty as, well, central Australia.
    Gillian and Chris
    Oh, and a Holden.
    Jan 2015
    A comfy place.
    319
    Oh yes, that was the post looks sexy clean. In to order it. Thanks.
    Gillian and Chris
    Oh, and a Holden.
    8,159
    Marco is away until September. . .
    Ici.
    2,523
    i've just made up an electroylis bath (800 litre) to derust and strip paint off panels, you could knock up a small one to do things like your clips for this section, works a treat and no boring muscle straining effort involved : )
    just google electrolytic rust removal, I ' m using caustic soda but ' washing soda' or sodium carbonate effective if disposal a concern, plus won't burn the s out of you if splashed! You just need a 6V battery charger, some wires with alligator clips, a plastic container and water! oh and a sheet of old metal to fit for anode.
    do NOT put aluminium in there!
    Last edited by forumnoreason; 19th August 2015 at 10:19 AM. Reason: additional info
    dspec likes this.
    Jan 2015
    A comfy place.
    319
    Any reason a 12v can't be used?
    (haven't googled yet)
    Gillian and Chris
    Oh, and a Holden.
    Jan 2015
    A comfy place.
    319
    So nothing will be sent til after then?
    Gillian and Chris
    Oh, and a Holden.
    Ici.
    2,523
    I'm using a transformer and you can control the amperage by the voltage, they tend to increase over a time period, people claim they have blown chargers for this reason I assume.
    Jan 2015
    A comfy place.
    319
    Thanks Noreason. And I've just received the email that nothing will be sent until after the end of August. So, nothing til September.
    Gillian and Chris
    Oh, and a Holden.
    Sep 2013
    Elphinstone Victoria
    535
    CITRO' SERVICES Srl
    I've just had a bit of success with this rubber strip. I took it off, coiled it up and let it soak in a bucket of mild bleach solution overnight.
    It actually came up quite well, lightly oxidised as you'd expect where it is exposed to light but discolouring and surface cracking is only noticeable if you get your glasses on and look real close. The three back panels and roof lining also responded to this treatment but I think I'll get the vinyl restorers to work their art on these soon.
    I may still go down the path of ordering a replacement rubber but it seems a bit needless at this stage. It will possibly do for another 10 years or so. At least it's available and easily taken out and replaced.
    SF
    Jan 2015
    A comfy place.
    319
    Ours is filthy and cracked everywhere. The new grey looks soooo clean I cant resist it.
    Gillian and Chris
    Oh, and a Holden.
    Ici.
    2,523
    putting the clip thingy back into it should be a nice way to drive yourself towards a bottle of Merlot, thry look like a p in the a to fit! nevertheless..
    Jan 2015
    A comfy place.
    319
    Maybe the cars owner will like to make it look pretty!
    Gillian and Chris
    Oh, and a Holden.
