Citroen BX Speedo Cable
Results 1 to 2 of 2
    Member jorgen's Avatar
    May 2013
    Launceston
    76
    Default Citroen BX Speedo Cable
    Hi, I am replacing my speedo cable on my 2 BX's and I will need to make ones.
    I remembered that I read somewhere someone made a continuous speedo cable without joins to avoid wobbling. It would be great if you can shed some light on it..
    I am I correct or did I dream this?
    Jorgen.
    Fellow Frogger! Mungous's Avatar
    NZ
    335
    Yep - I used to do that on a lot of cars. I'd take the two old cables halves into the instrument maker and they'd whip up a replacement single piece inner. Getting the length correct inner cable is critical.
