C5 Hydraulic fluid replacement.
Results 1 to 25 of 25
Like Tree5Likes
  • 1 Post By addo
  • 1 Post By GreenBlood
  • 1 Post By UFO
  • 1 Post By Greg
  • 1 Post By UFO
Thread: C5 Hydraulic fluid replacement.
    Fellow Frogger! paulrb's Avatar
    Dec 2004
    Geelong
    214
    Default C5 Hydraulic fluid replacement.
    Today a hose clamp failed on my wife's 2003 C5. And the power steering and suspension fluid all five litres, ended up on the road. It was towed to a repairer who replaced the clamp, but wants $80 per litre for specialist fluid. Which will need to be couriered in at extra cost. Is this necessary? $400 is a shit load for 5 litres of anything. I would put straight automatic transmission fluid in it if it was just the power steering. But I am a Peugeot head and the mysteries of Citroen suspension are.. Well Mysteries.
    So in short. Can 'normal' hydraulic fluid do the trick, or is there a sound reason to use a dedicated Citroen fluid?
    From the Peugeot infected mind of Paul Roberts...
    Current Beasts:
    '89 405 Mi16
    '98 406 ST TD Wagon
    '90 405 MI16
    '67 Morris Mini
    Recent Pugs..
    '94 306 XR
    '01 306 XT
    '98 306 XT
    Don't remind me!
    16,609
    It's important to use the correct fluid, otherwise the car may spontaneously catch fire and flip onto its back, all wheels quivering feebly on the ends of their hydraulic "legs" like a cockroach that's been well hit with Mortein.
    Have you shopped around to see what independent suppliers want for LDS?
    GreenBlood likes this.
    8,159
    I don't know of a substitute hydraulic fluid for the C5/ C6 so LDS
    Contact David Cavanagh of French Connection (I'm guessing you're in Victoria).
    aussiefrogs - The Australian French Car Forum Since 1999 - Forum Sponsor - French Connection
    Phone: (03) 9338 8191
    08 C5 X7 HDi very Noir
    8,592
    If it's orange stuff in a Hydractive it MUST be LDS. It isn't hard to find. My local parts-for-most-things place keeps it in stock.
    Victorian distributors are here - Distributor Network. If you can't buy it direct they'll know who stocks it nearby.
    Penrite also have a fluid they say is to the same spec.
    Dec 2004
    Geelong
    214
    LDS? Not sure what you mean here.
    I know David C well. He sold my wife the car and me $1,000s worth of bits.
    I can give him a call tomorrow.
    But I am not in Melbourne, do I love to find out more about this LDS in a
    alternative products. I think that they saw her coming and thought: most expensive option with highest mark up for us.
    Current Beasts:
    '89 405 Mi16
    '98 406 ST TD Wagon
    '90 405 MI16
    '67 Morris Mini
    Recent Pugs..
    '94 306 XR
    '01 306 XT
    '98 306 XT
    9,670
    The factory stuff will probably start at about $30-odd per litre, depending on where it comes from. It has been on offer as a Peugeot fluid via eBay for about that price and by a Sydney vendor who should know enough to mention Citroen in the listing headline. Full list + mechanic's markup + GST + freight could get you to $80/litre I guess. Penrite sells a version and it is probably the most easily found. EAI were selling a Ferodo version and it was of the order of $20 per litre when I bought some in Sydney last year.
    I can recall at least one earlier C5 that had been substantially topped up with LHM in error and had no problems after that had stayed in the system for the best part of a year, possibly longer. The two fluids are certainly miscible, but they are different, so it's not the best idea. Some parts, such as the strut return hoses, are used with both LHM (Xantia, XM) and LDS (C5).
    Brake fluid in the suspension and steering is the big error, but don't forget the C5 and C6 do use DOT4 in the braking system.
    Unless they can fully depressurise the hydraulics to check, set it to the lowest height and fill the reservoir to about the middle of the seam in the reservoir. Definitely, not checked at maximum height like the earlier LHM cars. Maybe exercise the steering and go up and down a couple of times to expel any air before a final check at the lowest setting.
    Dec 2004
    Geelong
    214
    Penrite's website lists a 'LDAS' that is a fully synthetic hydraulic fluid that is compatible with Citroen's Hydro pneumatic suspension. So i think that you guys have put me onto the correct stuff. Even if this stuff is $100 for a four litre bottle, it has to be better than $80 per litre. But I had figured that putting normal power steering or transmission fluid was not the best option. A bit like putting brake fluid in your power steering. You can do it, but you really shouldn't. So even though normal hydraulic fluid is probably safe, this LDAS OR LDS Or whatever it is sold has has to be a better option.
    Current Beasts:
    '89 405 Mi16
    '98 406 ST TD Wagon
    '90 405 MI16
    '67 Morris Mini
    Recent Pugs..
    '94 306 XR
    '01 306 XT
    '98 306 XT
    8,159
    Quote Originally Posted by paulrb View Post
    Penrite LDAS is no doubt OK but . . . it's a Green fluid and could cause confusion down the track. If you can find it close to you try to use LDS which is Orange.
    Try these Total distributors in Victoria (again I presume you are in Victoria)
    Victoria
    TOTAL
    ABSOLUTE LUBRICANTS
    17-23 Williamson Road
    Maidstone
    Victoria, 3012
    Australia
    Tel: 61-3-9645 4999
    Fax: 61-3-9645 6644
    Contact: [email protected]
    BBF LUBRICANTS
    1129 Latrobe Street
    Ballarat
    Victoria, 3350
    Australia
    Tel: 61-3-5336 1288
    Fax: 61-3-5336 1900
    Visit: home
    BJ BEARINGS DANDENONG
    461-463 Hammond Road
    Dandenong
    Victoria, 3175
    Australia
    Tel: 61-3-9768 3799
    Fax: 61-3-9768 3567
    Visit: BJ BEARINGS - Power Transmission & Industrial Supplies
    BJ BEARINGS WARRAGUL
    13 Endeavour Street
    Warragul
    Victoria, 3820
    Australia
    Tel: 61-3-5623 5444
    Fax: 61-3-5623 4108
    BJ BEARINGS WARRAGUL OUTLETS ALSO LOCATED IN:
    Bairnsdale, Campbellfield, Leongatha, Morwell, Pakenham, Sale, Traralgon and Wonthaggi.
    Tel: 61-3-5623 5444
    Gordon Brothers Industries Pty Ltd (Refrigeration and Food Grade Lubricants)
    21 Michael Street
    Brunswick
    Victoria, 3056
    Australia
    Tel: 1300 GORDON (1300 467 366)
    Visit: Gordon Brothers Industries Pty Ltd
    KAIROS Oil Australia Pty Ltd (Aviation Lubricants)
    PO Box 1500
    Camberwell East
    Victoria, 3126
    Australia
    Tel: +61-3-9996 1988
    Visit: Kairos Oil Trading | Home
    ELF
    PEAK LUBRICANTS
    224-230 South Gippsland Highway
    Dandenong South
    Victoria, 3175
    Australia
    Tel: +61-3-9799 0977
    Tel: 1300 722 256
    Fax: +61-3-9799 7709
    Visit: Peak Lubricants Supplier of Industrial and Commercial Grade Oils
    Greg likes this.
    Ici.
    2,523
    how good is this fella????
    8,592
    Not bad - it's my link!
    Dec 2004
    Geelong
    214
    Thanks. I'll give the total distributers a call in the morning. I'll see if they can improve on $80 a litre.
    Thanks for the info. It have been fantastic.
    Current Beasts:
    '89 405 Mi16
    '98 406 ST TD Wagon
    '90 405 MI16
    '67 Morris Mini
    Recent Pugs..
    '94 306 XR
    '01 306 XT
    '98 306 XT
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,892
    Sounds like this is a Citroen inspired fluid replacement interval of 12 years. If you cannot find one of these suppliers with LDS in stock, you might as well contact the importer for Australia which is Onshore oils at Hemmant in Brisbane and get it shipped directly to you.
    Sounds like the 1litre container I have in my boot might not be adequate for all circumstances.
    I am having an online chat with onshore oils are present and will report back if they come good with any info - they do not seem to list it on their product range - but I'm sure that is where I bought my 1litre container from ???
    Ken
    8,592
    The Total product is Fluide LDS, and I would be confident that Onshore would have it, but the Victoria distributors woukd have it too. Onshore are great to deal with and the courier fee might be worth it.
    Newcastle
    2,572
    Hi,
    Just to throw this in for the future information of others.
    The Citroen Car Club of NSW sell Fluide LDS to their members in 1 ltr bottles for $25. Have had it available for years now.
    Jaahn
    PS even $80 dollars a liter is heaps cheaper than printer ink
    Dec 2004
    Geelong
    214
    We put nearly 5 litres of Penrite LDAS in.
    We rang David C from French Connection and he said that the Penrite was interchangeable with the Total LDS. He reiterated that we needed to make sure that the fluid cannot mineral based. This is what a few of you also said.
    Autobarn sell the Penrite LDAS for $29.99 a litre. So for $150.00 we put the car back on the road, rather than the $400 we were quoted. This turned out to be what the local (Geelong, Vic) Citroen dealer were going to charge the local mechanic. This dealer also sells Great Wall and a few other makes of cars. Yet another dealer who owns a few badges and doesn't do our French cars justice.
    Current Beasts:
    '89 405 Mi16
    '98 406 ST TD Wagon
    '90 405 MI16
    '67 Morris Mini
    Recent Pugs..
    '94 306 XR
    '01 306 XT
    '98 306 XT
    Nov 2013
    NSW
    39
    Jan 2006
    east trentham / victoria
    26
    The Ballarat mob usually have 20 litre "bottles" of the Total products in stock or in stock within a few days. I bought 20 litres for my BX for around $200 about 12 months ago. I'm not sure if the C5 fluid is that much dearer. The bottles look amazing! Square and plastic but sturdy.
    Fellow Frogger! Greg's Avatar
    MAITLAND NSW AUSTRALIA
    617
    Hi Guys,
    For what it's worth, LDS is a Synthetic LHM, so if your really stuck, LHM won't cause any damage.
    Best regards,
    Greg
    We Have:
    We Had:
    Newcastle
    2,572
    Hi,
    Jaahn
    Hi
    This thread has risen from the dead for some reason. I just repeat my statement above. JOIN !
    If you drive a vehicle with a fluid that is hard to get, then you might be wise to buy a bottle when you can, and put it in the boot for when you cannot That's what I did. I believe 1 ltr would cover most normal leaks on a trip.
    Jaahn
    Citroën Tragic UFO's Avatar
    9,666
    Quote Originally Posted by Greg View Post
    Hi Guys,
    Best regards,
    Greg
    Greg, I recall stories in the Citroenian about people who mixed LHM into LDS systems and got mayonnaise. Non hydraulic functioning mayonnaise at that and pretty ordinary on chips.
    617
    Hi Craig,
    My info comes straight from the Greek God of Citroen, Spiro, (CC). He says that they have had a few cars come in with LHM, and they have just drained the fluid and replaced it with LDS.
    The quote, LDS is just a synthetic LHM is his.
    I suppose I've exposed one of my internal sources of info now.......Buggar!
    Best regards,
    Greg
    Best regards,
    Greg
    UFO likes this.
    We Have:
    We Had:
    617
    BTW,
    If you froth up LDS (aerate), it will turn a whitish colour, and its ability to aerate is why it sometime takes a while for the pump to prime after working on the hydraulics?
    Greg
    We Have:
    We Had:
    8,592
    My source says for LDS:
    Hydrogenated dimerization products of 1-decene, 1-dodecene and 1-octene - >80%
    Alkoxylated long chain alkylamine
    Methyl methacrylate
    Don't breathe or swallow!
    LHM is a mixture of petroleum distillates with a little phosphate.
    9,666
    Hi Craig,
    Best regards,
    Greg
    Best regards,
    Greg
    Spiro is frequently a source of lots of valuable information. We need a direct feed to that brain of his.
    Greg likes this.
    617
    Hi Craig,
    I'm probably the closest you'll get......LOL.
    You need an interpreter, as he is Tasmanian........ ROFLOL
    Brightest guy I've ever known, and he's often given me info re problems this forum. This might be as good as it gets, as he works with Citroen 5 days, has his own cars, and little spare time.
    Best regards,
    Greg
    We Have:
    We Had:
