Sophie
Results 1 to 16 of 16
Like Tree3Likes
  • 3 Post By Don B. Cilly
Thread: Sophie
    Fellow Frogger! Don B. Cilly's Avatar
    Dec 2014
    Mallorca, Spain
    437
    Default Sophie
    This car. 1972 DS 21, BVM, carb.
    I guess I might as well start a dedicated topic, however good these cars are, they are neverending stories...
    After months of (sporadic) work I fixed the electrical woes, thanks to Hotrodelectric and others here, got her on the road to enjoy it, and... the clutch started slipping.
    So, after about a month of rather more intensive work, heat notwithstanding, I got the clutch (and other bits while I was at it) together. And got it on the road again, only to have my wits scared out of me because she was overheating. Badly.
    Luckily I found the problem The air duct has a swiveling thingy (attached to a little chain under the steering wheel) to close it in sub-zero temperatures, and, well... it was closed.
    That solved, tuned a few thingies, it's running (let's hope for a while) well.
    So hey,
    I now have a beautiful DS. Beautiful.
    The 2175 engine is... man, it's so smooth.
    The clutch though... do you think you could help me tune it?
    Difficult to explain, but it's not quite... perfect.
    Oh it works OK. Once it's engaged, it's just fine.
    But engaging and disengaging... uhmm... not quite.
    And gear changing, could be softer.
    Any hints/tips/been-there-done-thats?
    I set it to engage at the bottom of the pedal run. I like it that way, but maybe...
    San Diego, California, USA
    3,543
    You might need to set the engagement just a little further up the pedal travel. The fingers in the pressure plate might need a little more room to work. You have the pedal height set correctly? Also- how old is the clutch cable? If it's original to the car, it might be stretched and just simply can't be set where it needs to be.
    At least you aren't suffering from the common RHD problem of a broken cable because it runs through a tortured path.
    Dec 2014
    Mallorca, Spain
    437
    Cable looks good and I'm sure I have plenty of room to set it, and the pedal height, to whatever I want.
    Thing is, how to find which is best with the least effort
    Coffs Harbour, NSW, Australia
    625
    The D series clutches need full pedal travel to clear properly from my experience. I presume that the L/H drive cars have a similar actuating, pivoted lever on the bell housing which wears & cracks as on the R/H cars, so check that is conveying full pedal movement to the clutch rod.
    Richard
    Mar 2011
    Ireland
    147
    Hi,
    I think it's only the RHD manual cars that have the fragile pivot on the bell housing. A bit of a bodge in the conversion to RHD I think.
    Ed
    Dec 2014
    Mallorca, Spain
    437
    I guess there's no shortcuts.
    Another one.
    Anyone been-there-done-that with this?
    Because I guess those little balls are supposed to pump the water to the windshield by circularly pressing the tube.
    Except... they don't even get near the tube at all, way they are.
    Should I try a bigger one?
    Los Angeles, CA USA
    1,955
    Any inlet of air to the plastic housing and that you'll will just spin.
    There are lots of things to be sure of on the clutch parts before you put it all back together. My guess is you are not getting full release. A frayed cable, which is very hard to see and easier to fix will cause your problem. As also mentioned, the pivot on the Bell housing only goes one way. Go the other way and you might be fooked.
    Los Angeles, CA USA
    1,955
    Long leg is cable end. There is also a bushing under the arm. If the arm shifts you will lose throw. Easy fix.
    Feb 2012
    Ongar / England
    868
    Being a cheapskate, I packed out the tube with some thin plastic sheet. It was enough to push the tube nearer the balls...
    Dec 2014
    Mallorca, Spain
    437
    Well, as I mentioned in the other thread, you get those how-do-I-spend the-next-half-hour moments...
    I finally put (quite a few of) those to good use.
    Tried all sorts of things, re-conditioning the old tube with hot water, vises, rivets and drill bits, using other tubes...
    In the end I solved it by using a softish irrigation tube I had, which still wouldn't pump, and packing a piece of (a different) tube, cut with scissors to shape, on the outer rim.
    Pump is installed and working, sorry I don't have any pictures, but I didn't believe it would really work until I had it in place, so...
    Dec 2014
    Mallorca, Spain
    437
    Now, that ugly white light thingy to the right of the clock, I would like to throw it away and put some sort of plastic cover in its place so I can then put some switches and things in it.
    I've tried to find a proper one, but could not. Suggestions, search terms... ?
    Or maybe Mr. ScotPrinterMan could draw one to print?
    Dec 2014
    Mallorca, Spain
    437
    OK, found it on ebay.fr. Plaquette, or platine, worked.
    3,543
    Quote Originally Posted by Don B. Cilly View Post
    Excellence. I would have gone with blanking plate, but whatever works.
    Don't toss the old one- some matt black plastic enamel and a little "chrome" foil intended for model kits works wonders.
    Dec 2014
    Mallorca, Spain
    437
    Well,
    I got the plastic cover.
    It's coming along really well for my sound equipment
    Dec 2014
    Mallorca, Spain
    437
    I'll tell about the equipment... someone might get some ideas he likes.
    In my case it was pretty much a forced path.
    I had these cables on one side, and two really thick power ones on the other (which is good) going to the boot.
    At the back I had three rather ugly holes, which I solved thus:
    (The basket I had hanging around, used it just to see if it fit, it did, I like the high-tech/low-tech contrast, and it's handy).
    So I got me a cheap but decent amp for the boot and a couple of decent Alpine speakers:
    At the dash, I had an empty hole, which I filled:
    I then added a push-button switch with LED (see previous post) to turn the amp off when I don't use the car, and a volume knob for ease.
    Easy enough if you already have the cables from dash to boot, but even if you don't, not too difficult.
    Reasonably unobtrusive, sounds good
    Sep 2013
    Elphinstone Victoria
    537
    Sorry Don,
    Didn't pick up on this in time. Next time though....
    SF
