Xantia fuse issues
    Ici.
    2,651
    Default Xantia fuse issues
    I've acquired a Xantia and it has a fuse shorting for the injector, number 7 in engine bay box on right side. previous owner had ignition "repaired" and they said the air blower was now also playing up, where to start I'm wondering?
    It's a series 1 97 turbo. I need a new seat too by the looks of it! plus this and that....
    Dec 2010
    Wagga Wagga
    361
    Not sure about injector fuse, but it is a well known Xantia problem for the heater cabin fan to play up. Unless fixed with "ignition repaired" the wire to the blower runs directly from the ignition key switch. When the starter motor is engaged a boost current runs to the blower as well, eventually burning out the ignition switch. Running a relay on the blower wire or getting power for blower from another auxillary source seems to be the answer.
    Ici.
    2,651
    ah that's interesting, I read on French Car forum about someone having exactly these issues and all they did was jiggle the harnesses which sorted something out.... I think it takes a 10amp.
    San Diego, California, USA
    3,543
    That sounds almost like a direct short to ground. I would be carefully checking the harness in the engine compartment for some rubbing or abrading damage. Check the connectors at the injectors and make sure they aren't shorting the terminals together. Extreme would be if the injectors themselves are shorting out. It's also possible the injectors are drawing too much current. And ensure all system grounds are absolutely cinched up. EFI draws rather a lot of power and depends on all connections being clean and tight.
