Sphere testing and re-gassing
Results 1 to 13 of 13
    Fellow Frogger! deesse's Avatar
    Dec 2010
    Melbourne Australia
    571
    Default Sphere testing and re-gassing
    Hi men,
    Can anyone suggest a good place to have the spheres on my SM tested and re-gassed if required? I will remove them from the car first.
    I am in the Northern suburbs.
    cheers Tony
    Jan 2006
    TRARALGON Vic
    43
    Paris Motors in Richmond can do the job. Should you ever go past Traralgon drop in, I have a tester.
    16,694
    Cccv
    Member wilrex's Avatar
    Oct 2014
    Buninyong
    79
    And, does anyone in Victoria fit new diaphragms?
    And, does anyone know of a source in Australia of the aluminium looking covering on the outer sill of a DS19?
    it is available OS but would prefer if someone had a roll of it here. It is actually an embossed fabric.
    wilrex
    2CV6 Special Green, Riley RMB, RX7 Rotary, Jensen Healey, 1896 Ford A replica, and last but not least 1961 Citroen ID19-P... Previous include, 27 Chev Truck, 24 Bean Truck, 27 Chev Capitol, Rover S105, Humber Hawk x 2, MGB, Ford AA Truck, Ford A, elderly motorbikes x6, and more...
    16,694
    Quote Originally Posted by wilrex View Post
    wilrex
    Roger parker in Adeliade will do new diaphragms in the spheres. I think the stock of LHS diaphragms is almost gone though. LHM is readily available if you have converted it.
    Aug 2011
    409
    The Citroen DS Specialist | Roger Parker
    [email protected]
    0438 809 237
    or in Victoria through the CCCV
    see www.citcarclubvic.org.au
    Dec 2010
    Melbourne Australia
    571
    Cccv
    Hi Shane,
    Does this mean you do spheres? If how long would it take if I bought the car to you on a Sunday morning (if this is an option as I will be going out country on August the 9th)
    cheers Tony
    16,694
    Quote Originally Posted by deesse View Post
    Hi Shane,
    cheers Tony
    I'm not sure who has the CCCV regassing gear. I'm assuming it's still Peter. I can regas spheres (using a dodgy home made regassing tool), but I need to get a gas bottle so would need to pass on the costs to whoever wants there spheres done ( about $75 for a d sized bottle and one months rental). If you find all your spheres are ok .... You still need to pay so I'm not out of pocket. However you can regas the spheres for all your cars for this amount if you bring a big box of them here....
    I however cant' disassemble/replace the diaphragms.
    I'd suggest the CCCV regasser will be much closer than ballarat so less effort for you.
    Oct 2014
    Buninyong
    79
    Yes, Peter Dekker will re-gas them, but can not replace the diaphragms, I gather.
    Roger Parker in Adelaide can do both, but he suggested David Graes? in Victoria may be closer. Is that correct?
    I think Paleades in Qld. still do them but not sure...
    What is the pressure required? Could be a tricky operation if HP is involved. OH&S paramount.
    Wilrex
    No clues as yet on the silver sill material for the ID?
    Symar/ca/usa
    607
    Wilrex
    SM = 40 bar front and 26 bar rear
    DS/ID= 59 bar front and 26 bar rear.
    Double check the size of the by-pass holes (center hole in the shock body) on those SM units - should be 1.45mm front and 1.25mm rear. If 1.8 or 1.6 they have been switched out for D units (this applies to the riveted shocks only)
    Steve
    Fellow Frogger! Don B. Cilly's Avatar
    Dec 2014
    Mallorca, Spain
    437
    IFHS spheres are €30 new. Haven't heard complaints either.
    Is it really worth regassing them?
    16,694
    Quote Originally Posted by Don B. Cilly View Post
    They'll be throw away junk. Keep the rebuildable original spheres Especially if they have removable dampers
    shane L.
    Symar/ca/usa
    607
    SM's never got the removable dampers - at least here in the US. I think the last year for D's was 1969. There was an interim assembly, at least on D's, of a riveted damper that was held in the neck of the sphere with a retaining ring. Not sure if we ever saw those here, however.
