Citroen Xsara, rear trailing arms?
    Jerangle
    775
    Default Citroen Xsara, rear trailing arms?
    Citroen Xsara with ABS what size are the bearings?
    Are the trailing arms the same as the Peugeot 206 GTI/CC ?
    Anyone got a link to replacing them?
    * The rear drum brake cars use the P205/P306 rear axle assembly .
    Just wonder if the rear disc/ABS set up is the same as the Peugeot GTI/ CC ?
    Jerangle
    775
    Sep 2003
    North Parramatta
    3,989
    The Xsara is mechanically a 306, not a 206.
    AFAIK, the Xsara/306 trailing arm is quite a different set-up, with the shafts on the trailing arm inserted into bearings in the beam, whereas the 206 has the bearings on the trailing arm and the shafts are part of the rear beam.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Jerangle
    775
    306 based.
