External temp sensor
    9,337
    Default External temp sensor
    Does anyone have any info on a TSB for fitting an external temperature sensor to the water outlet box in EP6 engines?
    Sep 2003
    North Parramatta
    4,008
    Is an "external temperature sensor" a coolant temp sensor, or are you thinking of something else?
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    9,337
    I'm talking about the EP6 plastic water outlet at the flywheel end, that contains a temperature controlled valve, and a built in temperature sensor. This sometimes fails. You see them advertised as a unit on ebay. I have been told there is a Technical Service Bulletin describing a fix, which reputedly involves an external sensor. Does anyone have any info on this problem and fix?
    Sep 2003
    North Parramatta
    4,008
    Ok, I didn't think there was a modification possible, but perhaps there is.
    AFAIK, there are two types of housing (outlet tank): one with a non-replaceable coolant temp sensor and one with a replaceable sensor.
    Simon
