D Steering column bearing
    Kapunda
    493
    Default D Steering column bearing
    As I have presently got the Steering col. housing on the bench having just dealt with the gear change column bearings, I thought I may as well check out the steering col bearings as well.The bearing consist of a number of 6mm balls in an uncaged separable assembly.The bearing will accept a max of 26 balls ,however 12 balls have been replaced with 2 plastic spacers,I am racking whats left of my brains trying to work out what is going on hear,I think I will fit 26 new balls!Any enlightenment anywhere??
    Woody
    10,126
    The spacers are legitimate Citroen and I think there should be more than two. Fairly sure they are shown in the parts book.
    8,249
    Yes, 648 shows 3 x 5.5mm nylon spacers and 9 x 6mm balls
    08 C5 X7 HDi very Noir
    Kapunda
    493
    Default Spacers
    That's all very well,but what is the point of the Spacers.
    Woody
    10,126
    Probably just less expensive than the ball bearings that were omitted. They may also have had some slight springy quality to keep the balls under slight load and prevent noises from falling bearings as you turn.
    19,211
    Or maybe the race diameter was not an exact multiple of the ball diameter?
