Secondary Air System Faut code P0341 & P0410
Results 1 to 2 of 2
    Mar 2015
    Kingscliff NSW Australia
    61
    Default Secondary Air System Faut code P0341 & P0410
    I have some more fault codes come up. Secondary Air System. Found my air pump not turning on, so unpluged the connection at pump tested for power with test light, yes have power but since found with test meter only have 5 to 6 volts reading at pump and at air sensor. Connected direct 12 volt power to pump motor and yes pump works ok. Now I guess I have to trace backwards to a fuse, guessing it would be maybe a 20 or 30 amp. any ideas where this fuse may be amongst the bank of fuses behind battery????
    Need Help here if anyone has had some experience with this fault.
    Mar 2015
    61
    Has anyone had the same fault on a c5? Could another c5 owner tell me if your Air pump (below Battery) turns on with ignition on only or when motor is running?
