Fuel injector fault P0201
  • 1 Post By cav91
Thread: Fuel injector fault P0201
    Mar 2015
    Kingscliff NSW Australia
    61
    Default Fuel injector fault P0201
    Hi my C5 (petrol) 2 litre has a P0201 fault coming up on the lexia.
    I changed injectors over from No. 1 to No. 2 still same falt comes up.
    Now am I looking at the correct No.1 from left to right? or is No.1 start from passenger side of car?
    8,615
    P0201
    Circuit ouvert ou court-circuit masse de la commande injecteur 1
    The French usually number from the flywheel/transmission.
    1000+ Posts cav91's Avatar
    Sunbury, VIC
    2,284
    Number one is usually the flywheel end on French cars. So yes the passengers side.
    The Dunk likes this.
    406 D8 V6 manual
    Mar 2015
    61
    P0201
    thanks for the quick reply. I had the feeling I got it wrong
    Mar 2015
    61
    thanks for the reply, Now I will start again - swap injectors that is and see if the fault moves
