The Thread of excellent threads!
Results 1 to 7 of 7
Like Tree12Likes
  • 8 Post By DoubleChevron
  • 1 Post By David S
  • 1 Post By GreenBlood
Thread: The Thread of excellent threads!
    16,702
    Default The Thread of excellent threads!
    The Special Tool Thread: The "Special Tool" thread
    The Car Manual Thread: The manual thread
    The List of Citroen Parts and Services: Citroen Parts & Service List?
    Rogers rebuilding a DS19 engine thread: DS19 engine reconditioning
    GibGibs 2cv restoration: 2CV Chassis Replacement
    Gerrys CX restoration: Gerry's CX Restoration--restored pics
    La Parisians DS21 BVH : 1969 DS21 BVH restoration
    mberrys 1968 DS21 : Ds21 1968
    Greenbloods DS restoration: GreenBlood’s D(very)Special Rejuvenation 2009>
    DoubleChevron's '63 ID19 Rebuild Is this the best project car you have ever seen?
    Greenbloods Dashboard rejuvenation:
    binnacle: GreenBlood’s D(very)Special Rejuvenation 2009>
    radio: D Model Radio Solution.
    dashboard: GreenBlood’s D(very)Special Rejuvenation 2009>
    Was after some info on seals etc. recently and tracked these three down:
    Hydraulic Pump exploration (Pottsy's home 7-piston seal kit)
    Canola Oil ... (... and when not to)
    Relacement seals and engine on old ID (Useful info for LHS>LHM etc.)
    Citroen C5 stuck in park: C5 Help urgent with auto gearshift
    Short thread on Eolys for C5:
    Correct EOLYS for my C5?
    16,702
    If anyone knows of a good thread we should include here .... and can actually find it Just add a message here, and I'll add it to the list
    10,100
    Useful Traction threads:
    Slough Traction interior lamps PLUS Slough tail light lens vs L741 often used (2017):
    Late english / slough traction interior light lenses?
    11BL Gearbox overhaul (Shane 2016): Finally ... Repairing a traction gearbox.
    4-speed TA gearbox: TA 4 speed
    The Longstroke DS/ID thread restarted 2013: Longstroke ds/id census
    Citroen Fluids:
    LHM: LHM .... compatible fluid ?
    DS21/23 5 speed oil: Gearbox oil recommendations Please- DS23 5 speed
    CX C-matic oil etc. (2018): c-matic maintenance...
    Particle filter / FAP Eolys - see Lexia and EOLYS? and Correct EOLYS for my C5?
    CX Tyres: Original Michelins for an early CX
    DS, CX and maybe BX stickers and placards:
    LHM & Air Filter Stickers
    Brochures:
    CX: http://www.citronpaper.it/CXdepliant/startCXdepli.htm
    Youtube channels:
    Servicing the Goddess UK 2019: https://www.youtube.com/channel/UC3T...fpn3uuv0HWDC0Q
    Coldwar Motors Canada SM project series: https://www.youtube.com/user/coldwarmotors
    10,100
    Threads re battery connected backwards / reverse polarity and BSI/ECU damage ...
    Incorrectly connected battery - Now no crank, no start - 2007 407 2L HDI
    C4/C5/C5/C6 et al. AM6 oil change info - Useful links inside this thread:
    407 SVHDI TT 2.7 Trany Fluid Change on Aisin Warner AWTF-80SC (06+ Aero Automatic)
    Buying C5 / VIN code / engine / trans version topics:
    Read through some earlier threads starting here:
    C5 info wanted
    Looking at the engine code in the VIN is the best way to know what you are dealing with when it comes to the confusing C5 range.
    C5 HDi 2.0 (01-05) electric fuel pump engine fuse box repair in this thread:
    HDI C5 wont start
    C5 HDi 2.0 (01-05) power loss. Tank pump and vacuum test info from factory manual at post 25.
    C5 power issue yet again or still
    C5/C4/C4 Picasso 2.0HDi DW10B RHR in VIN loss of power - turbo vacuum pipe Y-piece:
    C5 power down
    Applies to all C5 facelift and early X7, C4 and Picasso with 2.0HDi RHR engine and AM6 auto.
    Also applies to 307, 407 with 2.0HDi RHR engine auto or manual.
    C5 2.2HDi Twin Turbo (06-08) 6 speed (AM6) 4HS in VIN random limp / stalling >> Mixer/doser unit
    C5 depollution warning light
    C5 2.2HDi Single Turbo (04-06) 4 speed (4HP20) 4HX in VIN:
    No start / limp / Xmas tree dash: C5 2.2 Hdi error codes and loss of power
    Swirl vane actuator issues where car drives OK but faults randomly at higher speeds:
    Citroen C5 Swirl Valve Actuator Replacement
    Plus: C5 Limp home... and C5 HDi mystery lever...
    C2/C3/Pluriel Sensodrive threads
    Any sensodrive experts? Mechanic recommendations??
    See links in this thread re Sensodrive and some other Pluriel topics:
    Citroen pluriel gearbox
    C5 (01-08) hatch/boot doesn't open or opens by itself (=bad switch pad):
    Boot keeps opening on C5
    (Not to be confused with the C5 wagon (01-05, maybe to 08) tailgate glass that doesn't open because the printed circuit in the glass has gone bad. There may be a thread on that, but the fix is a bypass wire tapes to the glass. There was a Citroen kit.)
    C5 (01-08) Front window reg: Power window failure
    C5 (01-08) broken door handles Door Handles Broken inside and out
    C5 sticky dash coating: C5 V6 2001. Sticky, sticky dash plastic
    C5 X7 (08+) Door mirror repair: Citroen C5 X7 door wing mirror
    X7 door mirrors stop operating - Fuse for electric mirrors on 2012 C5?
    C6 AMVAR suspension valve dismantled (Youtube 2018) https://www.youtube.com/watch?v=Uqx5SfG-xRU
    10,100
    Thoughts on buying a DS23 Auto (2017):
    Potential purchase of a DS 23 1974 Pallas Auto...would appreciate some info.
    Some useful information on the DS power rack:
    Hoogy's DS 23 Pallas
    DS suspension issues, including choppy ride, stuck up and the wire in DS hydraulic pipes:
    2005: DS Ups & Downs
    2013: Stuck: front suspension stuck on high
    DS lost her bounce
    DS height corrector to anti roll bar connection
    DS is leaning to the left
    DS Spheres: DS spheres
    Consider replacing DS 2-piece accumulator spheres and servicing the regulator:
    DS/D Special - failed two piece accumulator sphere
    DS door assembly and window glass adjustment:
    DS19 windows roll up too far
    D Special door pockets
    DS (and GS CX etc.) wheel, hydraulic and minor parts paint info:
    Paint Codes for DS Roof/Wheels
    What Paint For DS Hydraulic Parts?
    DS engine bay brown colour code
    Discussions about the DS headlight bucket colour and wheel paint (critical topics!):
    2011: AC colour code for 68 DS 21 wheels
    2018: A tangent in this thread. Read from here, with more in mid-March 2018 ...
    My new purchase. 1974 Citroen D Special
    Headlight glass rubber: Late D headlamps rubber strips
    (Note 5/18 you can now buy both rubber strips as repro parts)
    CX rack rebuild (2004) Citroen CX Steering Rack restoration.
    CX Body colours as part of a useful site re the CX (French) (External site link)
    http://generationcx.chez.com/unlarge...uancierhtm.htm
    DS Body/trim colours (External site): Le nuancier, pictures of every Citroen DS ID colours colors
    ... including information on Australian and Heidelberg cars direct page links:
    Citroen DS in Australia and Citroën ID 19 Parisienne Australia
    CX A/C: Citroen CX Air Cond Options
    Step up idle (2018): CX S1 A/C and C-matic carburettor fast-idle circuit
    DS A/C
    York A/C Citroen DS
    DS21 Air Conditioner
    DS Electricals
    2017/18: DS alternator upgrade including BVH start lockout considerations in post 19: DS - New alternator with voltage regulator
    These threads will help on fitting a modern regulator inside the old black case on the battery:
    2016: DS voltage regulator wiring
    2011: using a modern voltage regulator in the DS
    Re BVH wand start and rectifier wiring:
    2011: In trouble again- DS electrics!
    ID/DS Jaeger clocks (2011-2017):
    Jaeger DS Clock
    Dealing with an insurer. Relates to hail damage Sydney Feb 2017.
    Hail damaged C5 potential write off
    XM/605 V6 (PRV / ES9) oil choices, capacities and PRV V6 dipstick measurements:
    PRV Bearings - Durability
    A thread (with linked threads) regarding the brake valve in Xantia, XM, most BX and probably CX post-82"
    Citroen Xantia Brake Control Valve Leak
    BX/Xantia/XM pinion service (2018 - tool kit diagram on page 2):
    Series 1 Xantia Power Steering very heavy and blowing rubber pipes.
    Xantia/XM strut top topics:
    Another XM Top Suspension Mount Bites the Dust
    Removing Xantia strut tops
    Some pictures of Xantia strut tops here:
    My XM has landed
    XM PRV V6 head gasket replacement on 1994 model:
    Xm - head gasket job
    PRV head bolt torque: PRV head bolt torque
    XM / 605 PRV Water Pump (addo 2014): Water Pump Rebuilding
    XM coolant reservoir: XM coolant reservoir
    XM PRV V6 radiator hoses ...
    Top - ado's fix (2014): 605 / XM PRV Top Hose
    Bottom (2017): XM V6 Bottom radiator hose needed
    XM PRV V6 4HP18 governor seals. In situ repair. May also apply to Peugeot 605 V6.
    XM V6 4HP18 Governor seals
    XM window regulator Bitron one-touch controller (2018) XM (Series 1?) Window Down
    Useful C4 threads, some applying to others:
    C4 1.6 HDi - considering purchasing - advice on engine & vehicle in general.
    Bungling Amateurs, C4 HDI injector, please help
    Dealing with a failed DV6 turbo - links to other threads in included in this one:
    Getting to know my new 07 C4 HDi - with your help please
    DV6 1.6HDi lube/care: 1.6 HDI Oil Lubrication and Maintenance. Avoiding Problems.
    Buying a C4 VTS with links to a couple of other useful threads:
    Purchasing C4 VTS
    Cleaning sticky soft-feel coated plastics in C5 (ad others), such as underdash etc..
    C5 sticky plastic dashboard?
    Click through to the linked thread with additional information.
    Can apply to any make or model using sprayed on soft feel interior coatings.
    A long thread that may assist with the AL4, or maybe just provide a lot of reading around the topic ...
    03 Citroen C5 2.0 HDI auto HELP
    That thread relates to an early C5 HDi, but there the material applies to others.
    Another early C5 HDi long thread that ended in a partial rebuild using parts from another AL4 gearbox:
    Update on C5 non starter
    followed by ...
    AL4 converter query
    and the follow on thread re the AL4 C&P. Link to useful manuals in post#12 if not already found elsewhere
    URGENT: Final drive needed 25x68 from 2L HDI AL4
    C4/C5/C6 Eolys variations and refilling:
    Lexia and EOLYS?
    On changing the Al4 fluid. Original pictures were lost. There may be a better guide now.
    Please re-post C5 AL4 transmission refilling guide
    Al4 in C5 no reverse (very short thread):
    citroen C5 with AL4 no reverse
    Changing the C5 dash cluster 2001-2004. Same technique, but different cluster 2005-2008 (pre-X7)
    How to replace a C5 speedo and rev counter?
    forumnoreason likes this.
    8,245
    08 C5 X7 HDi very Noir
    Apr 2014
    Phoenix, Arizona USA
    699
    TAV transmission rebuild
    Early DS water pump/low pressure pump rebuild
    DS19 early water punp/hydraulic pump rebuild
    John T.
