XM hand (foot) brake
Results 1 to 12 of 12
Like Tree2Likes
  • 1 Post By XM Mechanic
  • 1 Post By WRB
Thread: XM hand (foot) brake
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Default XM hand (foot) brake
    Hi,
    I changed the front pads and rotors on the XM and, now the parking brake goes nearly all the way to the floor. The factory manual states that you hold it down to the floor with the motor running and the hydraulics will take up the slack but, when I did this it made no difference. Any ideas?
    thanks
    Warren
    16,716
    You didn't break the springs in the calipers did you? The pistons needed to be wound in. To take up the slack, stand on the pedal a few times and the pistons should ratchet around and take up the slack.
    seeya
    PS: Have you had the "fun" of the release cable breaking yet .... Gee's I love XM's
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    No, I turned the pistons in and the brakes are working fine, it is just the parking brake that is affected. Cables are all intact and, while loose at the calliper, are connected...
    Sydney, Australia
    308
    It has probably popped out of the other end of the cable. It is in the transmission tunnel area. Just follow the cables from the front brakes back to what I consider to be an equaliser.
    UFO likes this.
    Garth.
    Fixin' Cit's.
    '19 308 GTi
    '15 DS 5
    '74 GS Convertisseur
    In the family
    '51 Traction
    '08 C5 X7 V6
    Previous ownership
    '95 XM V6 Series 2
    '96 306 XTDT
    11,225
    You didn't break the springs in the calipers did you? The pistons needed to be wound in. To take up the slack, stand on the pedal a few times and the pistons should ratchet around and take up the slack. seeya Shane L.
    My reading of the post says WRB is pressing the parking brake pedal and you are saying press the brake pedal to get it to adjust up, just like a BX takes up the handbrake when pressing the normal brake pedal. Assuming indeed that a cable hasn't popped out.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    16,716
    Yeah, that's what it sounds like to me. The XM is just a "big bx". He needs to pump the brake pedal to ratchet the pistons adjusters back out. Same deal with the old ID/DS clockwork brakes too
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Okay, I will give it a go with the normal brake pedal and see what happens. The thing is though is that I have working brakes and rhe parking brake pedal does take up but, nearly all the way to the floor. Maybe one of the cables has popped out of the equaliser so, will have a look on the weekend
    UFO likes this.
    16,716
    Quote Originally Posted by WRB View Post
    No you need to pump the handbrake .... it should spin the pistons as it's applied (if I'm not confusing it with the "D" clockwork brakes). Each time you apply the handbrake it'll ratchet the pistons around slightly. If you wound the piston all the way in, it may need to ratchet out quite a bit
    shane L
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,047
    I have found with my BX's that when the handbrake lever starts to run out of travel at the top, you need to do a few good panic stops with the normal brakes and this usually lowers the handbrake level by a few notches.
    In my experience, the brake pad wear is taken up during normal braking not when applying the handbrake.
    Ken W
    11,225
    Quote Originally Posted by Ken W View Post
    I have found with my BX's that when the handbrake lever starts to run out of travel at the top, you need to do a few good panic stops with the normal brakes and this usually lowers the handbrake level by a few notches. In my experience, the brake pad wear is taken up during normal braking not when applying the handbrake. Cheers, Ken W
    And that, presumably, is the equivalent of the parking brake pedal being down to the floor.
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Well, one of the cables has fallen out of the balancer, unfortunately it is the top one. I undid the exhaust heat shield but, could not move it back far enough to be able to access the top cable. I tried to turn it around the muffler to remove it completely but, wouldn't come out. The muffler is going to have to come out and, unfortunately, it is the one that goes up to the catalytic convertor and, I cannot access the bolts at that end so - off to Paris Motors.
    CitroŽn Tragic UFO's Avatar
    9,787
    No need to pump the foot brake pedal - push and hold firmly with engine running - and park brake released. Next application of park brake should see improvement. My BX failed a rego check years ago because of a slack park brake. Jumped in, started the engine, held the foot brake and then asked the mechanic to check the park brake again. Three clicks - PASS!
