The suspension accumulator sphere.
Results 1 to 18 of 18
Like Tree8Likes
  • 1 Post By Balki
  • 1 Post By George 1/8th
  • 1 Post By Citroenfan
  • 4 Post By Citroenfan
  • 1 Post By David S
Thread: The suspension accumulator sphere.
    Fellow Frogger! Lasya's Avatar
    Jan 2015
    A comfy place.
    319
    Default The suspension accumulator sphere.
    The accumulator sphere on my wife's D was obviously low (8 psi) so it was taken off to recharge. Guess what? It had a front suspension sphere instead of an accumulator. Is there a problem with this, and why would you do it?
    Gillian and Chris
    74 D Special, and now a 74 Pallas 23 5 speed with air(maybe). And now a Cactus!
    Oh, and a Holden.
    Lasya, Tibetan goddess of the moon and beauty who carries a mirror.
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,403
    A suspension sphere has a damper which slows down fluid movement. Bad idea for an accumulator, as brakes and steering may need fluid fast. I would do it only if desperate as a short term fix, and even then I would try to remove the damper.
    Roger
    Jan 2015
    A comfy place.
    319
    Roger
    Aha! Yes, but it's been there long enough to lose almost all it's pressure so I'm thinking it wasn't a short term fix
    Gillian and Chris
    Oh, and a Holden.
    602
    maybe someone put it in by mistake, or didnt know the difference,
    a couple of years ago i removed a GS accumulator sphere and found it was a suspension sphere.
    Good idea to put on the correct sphere
    Jan 2015
    A comfy place.
    319
    Yes, proper one installed and pressurised, but astounded. Me. I'm astounded. The sphere is pressurised.
    Gillian and Chris
    Oh, and a Holden.
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    631
    slight typo the sphere was 8 bar not 8 Psi, never the lees STUFFED
    Jinandfonic likes this.
    Jan 2015
    A comfy place.
    319
    Ahhrghh keep saying psi...
    Gillian and Chris
    Oh, and a Holden.
    Melbourne, Victoria.
    1,390
    Even very experienced Citroen people can accidentally put the wrong type of sphere on a wheel cylinder. I wondered why the rear end of my Xantia was bottoming out... the rear passenger wheel sphere is no place for an accumulator sphere. It was a long time before I realized anything was wrong. But geeez it was a huge improvement once I put the correct sphere in it's place.
    Generally , every wheel sphere should be a sphere with baffles. On a Xantia, all the extra spheres should be accumulators. However, on a C5 , the centre spheres have baffles. Go figure.
    cheers.. George 1/8th
    Jan 2015
    A comfy place.
    319
    There is also the possibility that someone knows that it doesn't matter if the accumulator has baffles as the pressure can still be distributed fast enough.... Anyone?
    Gillian and Chris
    Oh, and a Holden.
    1,390
    I think you should always put the right sphere wherever it's supposed to go. No exceptions. It matters.
    Lasya likes this.
    Symar/ca/usa
    607
    Quote Originally Posted by Lasya View Post
    Lasya,
    Really does not matter - at the pressures involved you will always get sufficient volume of fluid to power the steering - which is the greatest user of fluid volume once the car is at nominal ride height. Also remember that the fluid going into a suspension sphere encounters more resistance (by design) than flowing out. And if you are really concerned with it just drill out the by-pass hole (center hole in the shock if a riveted unit) to 3mm or so . If a replaceable shock sphere just remove the shock body.
    As to actual fluid use - brakes use hardly any fluid volume. And the pump puts out a lot of fluid at nominal engine speeds. If some one does not believe this just remove the return line from the regulator to the main reservoir when the engine is just running at nominal idle and see how fast everything is covered in fluid . And fluid volume is independent of the pressure - they are positive displacement pumps.
    OTOH a sphere that is down to 8 bar (166 +/- psi) is not a good candidate for recharging. Far to great a risk of the internal diaphragm rupturing in use. My personal rule of thumb is that if the unit is at less than 35% or so of its nominal fill pressure - just toss it. Failure rate starts going up exponentially.
    Steve
    Peter O likes this.
    Ici.
    2,649
    I woke up and looked at the ceiling fan and noticed it's main shape was uncannily like a sphere, thought if they ever stopped being available you could sand cast one, cut it in half, and use a small dremmel to carve out the inside. Then spend a few years figuring out how to gas it!
    Symar/ca/usa
    607
    Ya know - there are some excellent meds for this condition - some of which might actually be legal..........
    S
    10,090
    Quote Originally Posted by Citroenfan View Post
    ... just remove the return line from the regulator to the main reservoir when the engine is just running at nominal idle and see how fast everything is covered in fluid ....
    Exxon Valdez all over again!
    San Diego, California, USA
    3,543
    Funny, that. So do I.
    10,090
    Not to mention those speedometers marked in Furlongs per fortnight!
    3,543
    That's furlongs per rod, thank you very much.
    10,090
    Did you know that 55 mph = 147,840 furlongs per fortnight. Uniquely merican.
    Sounds faster. That's almost 150! (kFf ???)
    michaelr likes this.
