C3 head gasket removal: a how to do it...
Results 1 to 14 of 14
    ccc
    ccc is offline
    Member ccc's Avatar
    Dec 2014
    brisbane
    113
    Default C3 head gasket removal: a how to do it...
    Hi
    The Haynes manual for the 1.4L TU3JP engine has gone missing in the house and the head needs to have its gasket replaced over the weekend.
    Does anyone know of a web site or have the releveant section of the haynes manual scanned or in a file that can be emailed? I have all the gaskets & new water pump ready yo go.
    thanks Carl
    8,613
    This isn't the Book of Lies, but I hope it helps--
    Attachment 71103C3 head gasket removal: a how to do it...-tu3jp-1.jpgC3 head gasket removal: a how to do it...-tu3jp-2.jpg
    Tightening torques, order, etc (in English) are at http://service.citroen.com/dtt/CDP/d...us_t1_2005.zip
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,893
    I have a C3 Haynes Manual. From previous experience, its too hard to get a legible scan up onto AF. PM me with your email if you need help over the weekend.
    Ken W
    8,613
    Fewer dots/in, and cropped: C3 head gasket removal: a how to do it...-tu3jp-1a.jpg C3 head gasket removal: a how to do it...-tu3jp-2a.jpg
    ccc
    ccc is offline
    Member ccc's Avatar
    Dec 2014
    brisbane
    113
    thanks guys
    ccc
    ccc is offline
    Member ccc's Avatar
    Dec 2014
    brisbane
    113
    from memory before changing the head gasket the camshaft and crankshaft are locked in position with a 9? and 10mm? bolt thru pulley/sprocket wheels.
    Could someone please confirm these bolt sizes,
    thanks
    9,670
    This document may be helpful:
    http://service.citroen.com/dtt/CDP/d...us_c3_2002.pdf
    You also want to be careful that there is no erosion at the top of the liner where the gasket has failed.
    It's possibly not a bad idea to replace the timing belt, tensioner, roller and water pump at the same time.
    ccc
    ccc is offline
    Member ccc's Avatar
    Dec 2014
    brisbane
    113
    Hi David
    I dont have access to the service.citroen...... if you have the pdf could it be emailed?
    thanks
    9,670
    Try the link again. It was malformed. That particular document is not behind the paywall.
    North Brisbane
    1,893
    Default Page 1 of the Haynes Manual
    I have scanned the whole of this Chapter. PDF file is 5 Megabytes.
    Here is my first upload try of Page 1 using 500kb zip file limit. More to follow if this works.
    Ken W
    Attached Files Attached Files
    9,670
    The zip upload limit is 1Mb, whereas individual images etc. are 100kb.
    You can significantly reduce the file size for text and line diagrams etc. if you change the scanner settings to a 1-bit B&W.
    North Brisbane
    1,893
    More Pages
    North Brisbane
    1,893
    Thanks David. I was working to 500kb limit but this should get Carl there. Pics wouldn't look too good at 1bit depth.
    Must be dinner time.
    Ken W
    ccc
    ccc is offline
    Member ccc's Avatar
    Dec 2014
    brisbane
    113
    thanks heaps guys.
    Have replaced the passenger side top shock absorber mount. No more bumps and clanks.
    Will start on the head gasket in 2 weeks time.
    Theres also a german guy on youtube at https://www.youtube.com/watch?v=4cgGA9Rb0fA
    demonstrating gasket replacement on the tu3jp engine.
    thanks again for all the help.Will make some posts as it progresses.
    My sons 504 (avatar picture) is in the garage for 6 months after coming up from Tasmania.
    cheers
