Citroen DS 21.. A few questions
Results 1 to 13 of 13
Like Tree9Likes
  • 2 Post By Pierre Boulanger
  • 2 Post By Hotrodelectric
  • 1 Post By Hotrodelectric
  • 1 Post By Middlemoon.1
  • 1 Post By JohnW
Thread: Citroen DS 21.. A few questions
    Jun 2015
    Athens
    34
    Default Citroen DS 21.. A few questions
    Hello to all,
    I recently bought my precious DS and I'm going to need some help form you guys. I want to change the speedometer. The current one has water temperature indicator. The one that I fou
    nd from ebay has not. Is it possible to transfer the indicator to the new speedo?
    I'm also looking for good C colum trims. Any source for new ones or used like new?
    I will come up with more questions
    (Forgive my bad english)
    My DS (1971 EFI)
    Fellow Frogger! Don B. Cilly's Avatar
    Dec 2014
    Mallorca, Spain
    435
    You mean the instrument panel. right?
    Like this one?
    It's really quite easy to put the temp gauge in it, yes.
    Dec 2014
    Mallorca, Spain
    435
    Column trims, if you mean those above the back seat, to the sides, they are easy enough to have made, or make yourself.
    Fellow Frogger! Middlemoon.1's Avatar
    Jan 2011
    Alphington
    844
    What a beautiful car, Pierre! Congratulations. Is it manual or hydraulic shift? Has it always been in Greece? Colours look great. While the country may be experiencing austerity, it's good to see that this hasn't affected your ability to enjoy the best car in the world!
    Best wishes,
    Tim
    Jun 2015
    Athens
    34
    Quote Originally Posted by Don B. Cilly View Post
    Like this one?
    Yes this what I mean thanks!. Its easy for a pro or even an amateur? Its really essential to have it since DS's with injection are getting really hot sometimes.
    As far as the C column trims I can't make new my self thats for sure lol. I was wondering if you guys have a source in order to get a pair
    Quote Originally Posted by Middlemoon.1 View Post
    Best wishes,
    Tim
    Dear Tim,
    Thanks for the kind words. It was a dream for me to have a DS and thank God I finally have it!
    The car was in south France until 2011 and then for 2 years in Czech. Than my cousin that live in Austria bought it for me and before a month I drove her all the way to Greece. Amazing experience with no problems at all. The car it self cost me 6.800 euros + spheres and other minor improvments total 7.000 euros. Its 5 speed manual. The austerity is severe but i didnt had any second thoughts to offer all the money I had for her.
    To be honest my first love (since 1993) is below (1984 model):
    Jun 2015
    Athens
    34
    Like this one?
    Here is the current one
    Another pic of the car
    San Diego, California, USA
    3,508
    Quote Originally Posted by Pierre Boulange View Post
    Hello to all,
    My DS (1971 EFI)
    Hi Pierre-
    1) Don't worry too much about your English. If we can get what you're saying, you're doing just fine. And if not, there's a lot of words in English. We will eventually find the one that suits your need.
    2) Ask away. I tell everybody "dumb questions are easier to fix than dumb mistakes". I want these on the road, not sitting in a garage somewhere with some small problem that can be easily fixed in a few posts..
    3) Getting on to your question: yes, it's very simple to add the temp gauge. The lead for the sender in your case is already installed, so this becomes very simple.
    You will need to pull the instrument cluster. To do that, open the hood, and locate the speedometer cable. It should be running past the ignition coil and the alternator. About 1/2 way between these two pieces, you will find that the cable housing has a brass fitting that you unscrew. The cable becomes two pieces. With that, you can now remove the cluster. Go in the car. The job is a little easier if you remove the top of the steering pod first. Two screws underneath the chrome trim surround at either side of the steering column. Remove these two screws, and then work the top out. Place the car in 4th or reverse. Carefully remove the 4 screws that hold the cluster in place to the dash. Pull the cluster out enough to remove the speedometer cable and the 3 electrical connectors at the cluster. If you have a Pallas, there will be a fiber optic that goes from the cluster to the ignition switch. Simply unclip this from the ignition switch. Your cluster is now out.
    When removing or reinstalling the cluster, take great care that you do not snag or bend the corners of the cluster. DO NOT tighten the screws down beyond lightly snug. Those corners brittle and very easily broken.
    Now that the cluster is out, you can begin the swap. First, you will need to remove the knob for the warning check- the one on the left. It simply pulls off. If you're swapping the speedo, you'll need to pull that knob too. Again, it just pulls off. You might need to gently pry them off. Flip the cluster over, and you will see a series of IIRC 6 screws. Remove those screws, and carefully remove the circuit board. For the cluster you wish to swap to, you will see a blanking plate. Remove it and either discard it or keep it with your old cluster. On your old cluster, the temp gauge is attached with 3 nuts to the cluster board. Noting which way is up on the temp scale, remove the gauge. Again- be careful. These pieces are old and very dry, and the copper has work hardened over the years.
    Since you have the cluster out, now is the time to test and replace any bulbs that are burned out.
    As Haynes puts it, Reassembly is the reverse. The connectors are color coded in white/green/yellow. Just don't cross-thread the speedometer cable on reassembly
    Hope this helps.
    Fellow Frogger! Trading Estate's Avatar
    541
    The two tone colour scheme looks so good on a DS
    '04 Megane
    Gone but not forgotten
    '71 16 TS, '72 16 TL, '74 15TS,'82 20TS Series 2, '85 25 GTX. '49 L15,
    Jan 2011
    Alphington
    844
    What a wonderful drive you did, Pierre! Any pics or highlights from that! Wow. What a DS adventure.
    Tim
    Jun 2015
    Athens
    34
    Hi Pierre-
    Hope this helps.
    My dear Hotrodelectric I'm so grateful for the time you spent advising me. Thanks!
    i can now buy the instrument panel, print out your advices and give it a try
    THANKS!
    Tim
    I have many videos and pictures from the road trip.. During the next days I will finish the post process and of course I will share the video here with all of you
    During all this trip I felt like VIP..
    Admires in Ancona Italy
    3,508
    THANKS!
    Not a problem- you're quite welcome. If you have a problem, ask. That's why we're here. By the way, you needn't be so formal with me- the name is Bill.
    That is a nice pic. We need more!
    Pierre Boulanger likes this.
    Jan 2011
    Alphington
    844
    That is my dream of a European Holiday!!! We are headed to Europe following the D run in October. And although I plan to see some citroens, I don't think I'll be able to aspire to such a wonderful mode of travel!!
    Tim
    10,703
    Lovely car, Pierre. Just lovely. Nice drive too!
    Best wishes
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
