DS heater valve repair?
Results 1 to 19 of 19
Like Tree6Likes
  • 1 Post By mberry
  • 3 Post By mberry
  • 2 Post By DoubleChevron
Thread: DS heater valve repair?
    Mar 2011
    Broom
    815
    Default DS heater valve repair?
    Has anybody repaired the DS heater valve? I understand the seal goes and the valve leaks. Assuming this is the problem can the valve seal just be replaced thus fixing the heat leak. I know the whole valve assembly can be replaced easily enough for $170.00 but if a new seal would do the trick I think I would happily try that first....... Think this may have been why the 1970 was so much hotter in summer than the 69.
    9,670
    Some of them have a waxstat type unit inside it that is also linked to a Bourdon tube and is meant to regulate the temperature of water passing the heater core. Nice idea in theory, but if that's no good or the plastic body is brittle, changing the seal will not bring it back to work as intended. Most people have no great need for the heater and can just bypass the core with a piece of scrap tube. Cheapskates might be able to adapt a cheaper part with simple manual operation as used on some UK cars of the 1960's, similar to the Jaguar MkII style.
    1000+ Posts driven's Avatar
    Apr 2005
    1,407
    Check out this site for heater control valve ideas
    Metrix W0133-1903396 Heater Valve | Auto Parts Warehouse
    Fellow Frogger! rmac's Avatar
    Denmark, Western Aust.
    748
    I had two valves broken due to the plastic becoming brittle. A friend had a tinker and replaced the broken pieces with poly fittings. One he was able to thread and attach. THe other required some heat resistant adhesive that was used to bond the replacement part in place.
    Prior to this I used a 6" piece of aluminium tube to bypass the heater matrix.
    Current Cars
    Australia's 2016 C5 2.0HDi Last
    2011 C5 2.0HDi Comfort
    1973 Citroen D Super 5,
    1981 Citroen CX 2400 Pallas C-matic,
    1981 Citroen CX 2400ie Super Familiale C-matic - Raid Arctique 2014
    1991 Mazda E2200
    1924 Citroen 'la petit citron'
    Mar 2011
    Broom
    815
    Thank you gentlemen. Wishful thinking on my part, will get new valve unit and replace old unit, not that I really use the heater, but will maintain originality.
    GreenBlood likes this.
    8,159
    Icon11
    Quote Originally Posted by mberry View Post
    Useless junk only lasted 40 years Colin Smith has just been through this. . . hopefully you'll get another 40 years Michael
    Citroen DS Restoration
    08 C5 X7 HDi very Noir
    Mar 2011
    Broom
    815
    Thanks Chris,
    yes 40 years is pretty good, experience tells me not to expect anything like that from repro heater valve.
    9,670
    I suspect it might be a good idea to add a steel backing plate to stop the plastic fitting from bending when it's bolted to the heater core. It doesn't seem all that rigid.
    748
    The foam cushioning my heater matrix has powdered into dust. Will ordinary foam stand the heat or is it special foam?
    Current Cars
    1991 Mazda E2200
    San Diego, California, USA
    3,509
    Quote Originally Posted by rmac View Post
    I would think an ordinary, like a soft or open cell foam would dry out and crumble away in a short time. Something like a rubber-based padding- like the material used for mouse pads- would be the ticket.
    Do you have any of the original material at all to gauge against? Besides the dust, I mean.
    748
    No unfortunately. I'll try sacrificing an old mouse mat and see what happens. I was more concerned about it melting.
    Current Cars
    1991 Mazda E2200
    Mar 2011
    Broom
    815
    Default my lucky day
    Went hunting for a spare in the shed. Just a vague feeling I may have had a spare stashed.
    Was fortunate to find it, after cleaning and testing, it works, and seals, as far as I can tell.
    Unsure what kind of pressure it may be subject to, but, certainly worth refitting and testing in the car.
    Now I will disassemble the one from the car and see if I can repair. It's responded well to cleaning, just not sure it is sealing.
    Attached Thumbnails Attached Thumbnails DS heater valve repair?-heater-valve.jpg
    3,509
    The pressure won't be great. No more than system pressure, which IIRC is only 4lbs.
    Apr 2013
    Essendon
    648
    Subjected pressure will be no more than the pressure rating of the radiator cap Mike.
    John
    Mar 2011
    Broom
    815
    All seems well with the replaced heater valve, gave it a good road test last night with no problems. Having been through this exercise I'm taking the small radiator in for a recond. From now on as a matter of maintenance I will flush the heater radiator and clean/descale the heater valve whenever I flush the cooling system. Hopefully that will ensure the longevity of the heater valve. Can't believe I didn't tend to this earlier, had some very hot trips over the summer......
    Mar 2011
    Broom
    815
    Default The offending seal
    It doesn't look particularly good, but I suspect a new seal can be made. The mechanical mechanism still serviceable. Any thoughts greatly appreciated.
    Attached Thumbnails Attached Thumbnails DS heater valve repair?-img_8073.jpg   DS heater valve repair?-img_8077.jpg
    16,329
    Before you refit it .... make sure you car still has the correct 4psi radiator cap there.... Most have been replaced with whatever is available at the local auto store. 11+psi may well cause the tap to leak where it didn't at 4psi
    Hotrodelectric and mberry like this.
    9,670
    Is there any change when the tube is immersed in hot/cold/hot water? You should be able to get some idea as to whether it might self-regulate when installed or whether it is stuck.
    Mar 2011
    Broom
    815
    David, with the one that I have opened up, it was certainly sticking. The rubber seal seems to have deteriorated markedly. I don't expect the heat is moving the plastic tube, it's that extremely hard style plastic that the blower housing is made from. I have a price coming tomorrow for a new seal made from silicone, hopefully doesn't cost more than a poor quality repro. heater valve.
