Part Numbers for Harmonic Balancer, Water Pump Timing Belt and Seals
    269
    Default Part Numbers for Harmonic Balancer, Water Pump Timing Belt and Seals
    Hi
    We have an early 2005 2.0 litre petrol C5 and its coming up for a timing belt replacement.
    I'd like to replace the following:
    Timing Belt
    Water Pump
    Oil Seals
    Harmonic Balancer
    The cars VIN Number is VF7DCRFNF76476561
    Can any one give me the part numbers of the items I've mentioned above, eg Valeo XXXYYY?
    Regards
    Alan
    Oct 2014
    Brisbane/Australia
    463
    Ask your local CitroŽn dealer for part numbers.
    Sent from my SM-N910F using Tapatalk
    9,300
    With the VIN, part numbers can be got from the Citroen service site.
    Also this mob will know - EAI: European Auto Imports. Provide them the VIN.
    I'm not sure if he's still there, but About ? French Car Service Parts would know too. Both of these are in the Hornsby area, but will courier to you.
    At Granville, Colliers would know and can supply also - Specialists in Renault and Peugeot Service and Parts.
    269
    seasink & dcc236
    Thanks for the leads. I'll follow them up.
    Melbourne, Victoria.
    1,390
    Hi Alan, have you done one of these before? I did the belt on my Xantia, also a 2 ltr petrol engine. It's a very good idea to change the harmonic because they have timing marks which slip around with time and so cannot be relied upon. The new one should be right, however even then I'd go by the woodruff key position in conjunction with the TDC of the number 1.
    Good luck...
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Pop your vin in here and you will be able to get all of the part numbers CitroŽn Service
    Euro imports in Box Hill can work from the vin as well
