citroen bx 16v bad idle
Thread: citroen bx 16v bad idle
    Oct 2014
    Moonee ponds
    32
    Default citroen bx 16v bad idle
    so i just spent the last 4 days fitting a new starter motor to my 16v. i don't think i disturbed anything when i put everything back together, but now it's idling weirdly, and just as i took it out for a spin today the engine entirely cut out at 2000 revs. has anyone had this problem with a 16v before?
    Fellow Frogger! Mungous's Avatar
    NZ
    335
    Air leak would be my bet. Check all the rubber hoses (including inlet tube from air cleaner) to make sure everything is connected properly and has no splits.
    Oct 2014
    Moonee ponds
    32
    ahhhh ok, thanks.
    Nowra, NSW, Australia
    237
    Check the electrical plug to the air flow meter - near the air filter. Also the knock sensor plug next to the oil filter. Sounds like a electrical/sensor problem to me.
    Michael
    BX16v
    C5
    BX Estate - 4sale
    1000+ Posts dino's Avatar
    Nov 2002
    4,708
    Quote Originally Posted by Youngblood View Post
    Did you disconnect the battery during change of starter... if yes... i d recheck battery terminal connection...
    Sometimes the most obvious escapes us...
    cheers
    dino
