ZF 4 speed "sealed for life" (XM)
Results 1 to 8 of 8
Thread: ZF 4 speed "sealed for life" (XM)
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Default ZF 4 speed "sealed for life" (XM)
    So...
    How do you know your gearbox is about to explode.
    Mine is getting hung up in gears and changing up or down erratically. Other than that, it seems to be working fine (the car goes)
    thanks
    Warren
    16,743
    You didn't put Dexron III in it did you ? If so the fluid has probably turned black and the valve block is starting to stick from the contaminated oil. The slugoamtic in my old XM was completelly and totally worn out, but still worked as designed at 250,000miles...... 'Cos it has never been contaminated with Dexron III.
    Don't remind me!
    16,609
    Mileage, 160K is about the lifespan.
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    I had the fluid changed at the Citroen place in Box Hill. I think I will take it to the ZF specialists in Dandenong to get a diagnosis.
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Just called Auto Paris who changed the fluid around august last year and they said they do not use Dextron 3 but, a fully synthetic fluid that the get from Renoult
    16,743
    Quote Originally Posted by WRB View Post
    Oh ignore me ... You must have a later XM without the 4hp18 .... Sounds like they did the right thing
    Maybe a 4HP20 ... It's a box with electronics right?
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    Sealed for Life transmission...be the only thing on a Citroen that's sealed
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Yeah Shane - 4HP20
    Could just be sticky solenoids... I was just out in it and for the majority of the journey, it behaved itself.
