C3 1.4 emulsified oil in header tank
    ccc
    ccc is offline
    Member ccc's Avatar
    Dec 2014
    brisbane
    114
    Default C3 1.4 emulsified oil in header tank
    Theres no emulsified oil under the rocker cover; so a one way leak thru the head gasket.?
    Anyone had experience with this? Is it common with the C3? 2002.
    thx
    Don't remind me!
    16,609
    It's common. The integrated o-ring seal on the head gasket's orifice for oil transfer to the head, fails.
    Oil will eventually rot your top radiator hose.
    The fix is a new head gasket - use a VRS kit - and new head bolts. Treat the sealing faces and replacement gasket with a generous spray of Hylomar. Once reassembled, bleed, bleed, bleed again. Flush the cooling system several times to remove oil, too.
    9,266
    Gee VRS brought back memories - I haven't had to regrind valves for eons.
    ccc
    ccc is offline
    Member ccc's Avatar
    Dec 2014
    brisbane
    114
    Last did this with a datsun 1600! I get the flush of the cooling system, what needs to be bleed on the engine after replacing head gasket?
    thanks guys
