DS LED headlight upgrade.
Results 1 to 25 of 27
Like Tree10Likes
Thread: DS LED headlight upgrade.
    Mar 2011
    Broom
    819
    Default DS LED headlight upgrade.
    I'm still driving around with original lighting on my DS's. Being lazy may have put me in good stead for jumping a couple of generations. With all these new modern headlights blinding me at every turn.
    Has anyone tried a modern LED headlight upgrade on a DS?
    I drive the DS as an everyday car, so the lighting has started to become more of an issue, they were well advanced compared to most of their contemporaries, but the lighting, like the power plant was a little under done. I'm thinking I can jump straight into the latest technology, tell me I'm wrong.
    I'm thinking I can take a modern light 'with' it's reflector and fit it into my headlight, the new LED's are tiny.
    May 2012
    393
    Hi Michael,
    I am thinking the same but suspect we are not quite there yet. I looked (mainly ebay) at led replacement bulbs for all the rear lights and indicators and it is a confusing area but full of promise. Attractive to get real red and real amber ones given the faded lenses on my ID. There are dozens of chinese sellers and a few UK ones, not sure if I have seen local ones. But headlights I am not so sure of.
    We need someone to blaze the trail for us. My main issue remains lack of time so these ideas are not getting turned into action at the moment.
    To complicate matters, strictly speaking my headlight bowls need replacing or rechroming and I found both options difficult and expensive - probably over $250 per light for either option. No easy answers sometimes.
    regards Leconte
    1962 Heidelberg ID19 "Axel"
    1965 Heidelberg ID19
    half owner 1974 GS 1220 Convertisseur Break
    San Diego, California, USA
    3,543
    I think Corne (Cornesoutafrica) did that with some success. He used the original reflectors (they were trashed) as framework for the new reflectors and lenses. I haven't seen him here for awhile, but you can try to PM him, or maybe get his email address from his profile.
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    561
    For headlights you need HID not LED ,
    I think the DS uses H1 globes and there are plenty of straight swap HID kits to suit H1.Try E bay for replacement globes ,
    I converted my 504 headlights to HID and the difference is dramatic , I can see again.
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    Oct 2003
    Hampton Park
    523
    I tried HID but the lamps themselves need to be modified
    Relays and re wiring the originals is an option also I note only the later Ds seem to have QH bulbs
    An obvious improvement
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    If you want to be a friend to other road users, do not go the HDI route. The lenses and reflectors on a D were never designed for them and are not accurate enough to control the light projection. I would not do it to a CX either.
    I assume you have relays feeding the lights, so I would suggest you by some +100% Halogen H4 and H1 globes. Phillips make them. They put out twice the light with the same power input well within the capabilities of the light units. I have these in the CX and they make a noticeable difference without blinding other road users
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    Banned Haakon's Avatar
    May 2002
    canberra...
    8,876
    LED headlight globes are a thing now. Even the base model Corrolla is LED equipped these days.
    160W 9000LM Cree LED XML CAR Headlight Kits H4 HI LO Replace Halogen Bulbs 6000K | eBay
    LED tend to be better thna HID globes because the point of illumination is more aligned to where the filiment on a halogen is - this is important because it affects the behaviour of the reflector and if mismatched (ie putting cheap HID kits in reflectors designed for halogen) you get random glare and poorly cut off low beam - ie piss off your fellow motorists.
    LEDS can also be used for high beam as they illuminate immediatly, unlike HID which is a low beam only affair as they take a couple of seconds to warm up.
    I would look at not using the original reflectors at all for low beam, and installing a projector lense. The aesthetics will be a challenge
    3 0" Universal CAR Headlights HID BI Xenon Projector Lens KIT Halo Angel EYE 55W | eBay
    3,543
    Both are available. My preference is for QI, but that requires near perfect reflectors
    .So does HID. The LED lamps have the advantage of already being self contained like a seàled beam. They're not as good as QI or HID For lighting. They are an inexpensive solution to an expensive problem.
    16,743
    I don't like those HID headlights that "blast" you with high intensity light as the car goes over bumps. I reckon high beam is excellent in a DS, especially if you have fitted headlight relays and have good chrome on the reflectors. Low beam however is terrible.
    As much as I hate those HID's, they'd probably work well in a DS's low beam. You see, if you made sure the headlight leveling wires back to the rollbars were un-seized and setup correctly, you in theory should never give other road users the "blast" of high intensity light as your driving along.
    Mar 2005
    922
    I have recently been down the HID replacement situation in order to upgrade the performance of a Mitsubishi Challenger .. standard H4 bulbs. As mentioned above the lens patterning didn't suit the HID light source.. a good pool of blusih green light on low but no benefit on high. The trouble with HID bulbs is the "ignition" time and having to initiate burn between low and high would mean momentary darkness when one source was extinguished and the other getting up to temp. The replacements actually have ONE light source that is tilted into a different position for lo or hi beam use. I have replaced the HIDs with original H4 ... unless designed for them the HID conversions are not worth the effort.
    1000+ Posts driven's Avatar
    Apr 2005
    1,563
    HID lights need auto self levelling and cleaning ability I read on the Vicroads website
    Check your state rules for aftermarket fitting
    16,743
    Well ... they are talking about putting them on a DS ... possibly the only car ever made with "real" leveling headlights ... Not only doest he car itself self level, so do the headlights!
    1000+ Posts Richard W's Avatar
    May 2012
    1,383
    Citroen may have been the first many years ago, but these days it's pretty standard. Every car that comes with OE HID lights must have "real" self levelling beams. However, levelling the beam is meaningless if said beam is poorly focused and throws light where it shouldn't because someone's put a cr*p HID bulb in a lens that was never made for it.
    Those LED H4 bulbs look even worse - instead of a single point source for the light, the light would seem to come from a range of LEDs spread over more than about 30mm, and nothing at all from the centre of where the original lens would have focussed. How on earth is that going to focus properly and give a clean low beam cut-off? I think anyone selling that stuff should be prosecuted - except they're no doubt all dodgy vendors in China.
    I don't know anything about Citroen lights and their mounting points, so I'm probably showing my ignorance, but why is it not possible to adapt a nice Cibie or Hella 7" QH insert? Put a high output QH bulb in those and surely it's enough light.
    Don't remind me!
    16,609
    You touch on an interesting point, all the Osram (to pick one make) HID and LED globes in H4 seem to be coming from places like China or India.
    Being that Mr Berry's car is probably one of the best in Australia in condition and "correctness" I am looking forward to an elegant and discreet modification story.
    8,257
    Icon3
    Well I'd be hoping that the car remains one of the best and with minimal modification, or I'll have to disown Michael!!
    Michael if you have the twin reflector style lights dump them and replace with the later improved singles using H4. . .
    08 C5 X7 HDi very Noir
    719
    Hi Michael,
    Just a few comments...
    I have NOS headlights and inner spotties with the standard 35/45 filiment globes in the main and 55 w halogen in the spots. The light is brilliant and not far off that of a modern car.
    So the reflectors and contacts in the relays behind the dash are important. If your lights are original then the reflectors are probably past it.
    Often people fit higher wattage globes which draw more current and generate more heat which accelerates the deterioration of the reflectors and relay contacts.
    So first I'd look at replacement lights and clean the contacts on the relays and the slide connectors at the relays, switch and guard to ensure your getting 13+ volts to the globes.
    HID is illegal and at higher wattages will destroy your reflectors.
    LED is not there yet as a substitute.
    IMHO I would spend the dollars on getting the factory system working properly.
    Hope this helps....
    Mark...
    Mar 2011
    Broom
    819
    some great advice here, and a couple of different view points, as expected. I have already done quite a bit of research, and there are some serious legal issues associated with modifying headlights. Very interesting reading. However, Chris is right, I take some pride in the originality of my cars, but, if a suitable modification can be found, I'm happy to consider it. The standard beam is simply not adequate, I will be upgrading. The question is which way to go, I certainly don't want to be responsible for blinding someone and causing an accident. So I'm progressing with caution, and I'm not interested in anything that doesn't look original., so the path is becoming more defined.
    May 2012
    1,383
    For what it's worth, our daily drive has HID lights as standard. They're good lights, but i don't think HID is hugely better than good halogen lights to drive behind. If you can get good halogen inserts of some variety in there and use some of the newer 'plus' halogen bulbs that claim 80% or 100% more light than the original then I'd be surprised if it weren't more than adequate...
    Tadpole dherrick's Avatar
    May 2013
    Auckland, New Zealand
    20
    I've been down this route with my 69 DS21. The original 45w/55w system had dangerously poor output for driving on city and country roads, so the upgrade I used was as follows and has delivered the best performance of all the cars I've owned, including moderns with HID's:
    - bulbs on dip/high and turning spots replaced with 100w units. These were special ordered Narva units from SuperCheap, weren't expensive from memory.
    - 3 x fused 30A relays, mounted discreetly on the battery frame (Automotive Fused Relay - SPST 30A | Automotive | Relays & Accessories | Electromechanical Components | PRODUCTS | SY4077 | Jaycar Electronics)
    - heavy gauge wiring from the battery to the relays, then from the relays to the bulbs
    - better earthing
    - modern 4-way plug/socket hidden in each front guard to allow the lights to be quickly unplugged to remove a guard. Also from Jaycar.
    I haven't had any issues with the heat of the bulbs damaging the lights, as they are 'old fashioned' glass/metal units (the chrome inside them isn't fantastic either), not the plastic meltable units found on modern cars. Compared to +50 and +80 55w bulbs I've used on modern cars the 100w bulbs are brighter and also cheaper. With properly aimed lights you don't get flashed and the car has no issue passing inspection. I haven't had any issues with excess battery drain at night. The light output is very good now, driving at night is actually enjoyable and safer. Overall I really recommend it.
    Fellow Frogger! renault12's Avatar
    Sep 2005
    Sydney, Australia
    430
    Ha! My regular eBay session has revealed something you may be interested in. Not my thing.. But check these out:
    http://pages.ebay.com/link/?nav=item...obalID=EBAY-AU
    Could be worth thinking about should the LED road be the one you wanted to head down...
    Fellow Frogger! meinkiev's Avatar
    Aug 2011
    Kenya, Africa; Kiev, Ukraine, and Albury, NSW
    138
    I have just installed LED H4 bulbs (Autofeel 7600 lumen) on my CX. They replace Philips 100% QH. They make the QH look like candles side by side, and have very clean low beam cut-off and focus. There is a huge amount of rubbish out there so choose carefully.
    I also have a question about my S2 CX Turbo which has H4 main bulbs coupled with smaller driving reflectors. Can someone tell me what bulb type goes in these? The car is in Europe so I can't check easily.
    1,003
    Not on a DS, but I've replaced all my lights on racecar with LED. Spent longer than would be recommended comparing different options.
    I ended up with OSRAM/Sylvania Zevo LED replacements. They are very good, much brighter and faster response, while on a way lower current draw.
    For all the indicators and brake bulbs etc, I found an equivalent that would fit. It's important to remember to get matching output colour to the lens it will be shining through i.e. Red brake lens uses a red bulb. It's tempting to get white for all and let the lens modify it, but apparently that's not correct for LED bulbs and you'll get lesser output.
    One issue you will find is for flashers that use the current draw to hold the flash rate on against a spring, the current draw will be way too small.
    This is an example of the brake light bulb
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    1984 505 Executive Auto
    206 GTi 180 - '804 Cat Cams, Jenvey DBW 48mm ITB's, AT Power Dry Sump, Emtron KV8 ECU, HP Electronik PDM, AIM MXS Dash, Custom Wiring Harness. AST Camber Tops & Coilovers, -2deg camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, Custom Radiator and Oil cooler, 3J Plate LSD, E85.
    Sandown - 1:31.5, Winton - 1:40.2, Wakefield - 1:11.05, Phillip Island - 1:55.9, The Bend (International) 2:23.2
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,166
    Quote Originally Posted by speaksgeek View Post
    Diverging on to indicator systems for those of us in Tractions that still have operative semaphore signals there is the availability of festoon "flashicator' bulbs from this company in the UK Classic Dynamo & Regulator Conversions
    I have them in my Light Fifteen and they are brilliant. People now actually take notice of the signal when the arm is extended.
    Cheers Gerry
    6,665
    Me, if DoubleChevron doesn't chime in here, maybe message him - he'd know.
    2003 PEUGEOT 206 GTi
    Jun 2016
    Newcastle NSW Australia
    120
    The advice I’ve seen online suggests that LEDs give the best results when the LED is mounted to the fixture at the same distance from the base as the original element in the original bulb. This setup will then still compliment the design of the reflector...
    I think this is distance is about 25mm.
