CX brake valve becomes noisy
    Member Houtan's Avatar
    Apr 2014
    Tehran, Iran
    72
    Default CX brake valve becomes noisy
    Hi
    When I press the brake pedal, Braking valve or maybe pressure limiter becomes noisy and I can hear hydraulic liquid`s voice, What is the problem and what can I do?
    16,754
    Quote Originally Posted by Houtan View Post
    Hi
    Try bleeding it... but don't worry you can treat it as normal. I find the ABS cars do it more
    shane L.
    1000+ Posts michaelr's Avatar
    1,393
    Agreed, bleeding is probably the answer. Air in the system causes rushing noises and also leads to delayed brake response and a hesitation in releasing the brakes when foot removed from pedal.
    Michael
    Member, Citroen Car Club NSW
    Apr 2014
    Tehran, Iran
    72
    Thanks, I will try to bleeding, I`m not using this car every day and when you park a car months problems coming from every where.
    Cheers..
    Symar/ca/usa
    607
    Cheers..
    Take a look at the accumulator sphere attached to the brake valve and have it checked. Quite possible it has developed a slow leak of N2 into the system. Unless the system has been run low on fluid that, typically, is the primary reason the brake system gets gas into it.
    Steve
    Sep 2013
    nz
    69
    I get a similar noise from my steering wheel when i release it from opposite lock? perhaps a bleed of the steering system may also help?
