THP155 Timing rattle? - Page 3
Page 3 of 3 First 123
Results 51 to 58 of 58
Like Tree6Likes
Thread: THP155 Timing rattle?
  1. #51
    1000+ Posts TroyO's Avatar
    2,513
    That would often be the case for me as well, it wouldn't be noisy every morning. Sometimes there didn't seem to be any pattern to it.
    My dealer did find that the chain had stretched, I guess they could have determined that if they measured the deflection on the chain.
  2. #52
    Sep 2003
    North Parramatta
    4,008
    Quote Originally Posted by Dave View Post
    My car has had basically perfect starts for 5 consecutive mornings since staying at the dealer overnight. So...what did they secretly put in the oil?
    Geez, Dave.
    You're giving us the impression that it's started once a day - possibly by the apprentice on his way to the shops with the bacon and egg roll order for the boys - and that's it.
    Have they checked for chain stretch? It's a relatively simple procedure that involves removing the tensioner and inserting a go-no go gauge and measuring its length.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
  3. #53
    Jul 2012
    161
    Citroen and Peugeot have apparently revised oil recommendation for THPs to 0/30w (total) apparently mitigates against timing chain cold start issues (faster flow) but curiously also to reduce carbonisation. My THP had the chain done under warranty 4 months ago, and they have advised me of the new oil type.
  4. #54
    1000+ Posts Dave's Avatar
    Apr 2001
    1,340
    Quote Originally Posted by SLC206 View Post
    Geez, Dave.
    No, unfortunately I'm pretty sure they just plugged it into the computer and used the software diagnostic to say that the timing is within spec.
    Regarding oil when they did the 10k service for me (when the car had about 8k on it) it says on the receipt they used the Total 5W30. I wonder if as I put more km on this oil the tensioner is behaving better? Then again it didn't make any difference for at least 5000k.
    Dave
  5. #55
    2,513
    On my last service in April they used Total 5W/30 oil.
  6. #56
    Apr 2001
    1,340
    Had another chattery start up this morning, will just keep monitoring for a bit.
  7. #57
    Jan 2015
    ACT
    62
    Hi Dave, where did this land for you? About 8 months since I had my timing chain done and no issues with limp mode. Seems to have done the trick. Makes me think if the previous owner had been aware if they'd have got it repaired under warranty. Apparently the car was in and out of the shop because it constantly went into limp mode and they never diagnosed the problem.
  8. #58
    Apr 2001
    1,340
    Mine is still happening intermittently. Most commonly on the after work startup.
    I will talk to them again at the 30 000k service.
