ID19 Noise
Results 1 to 16 of 16
Thread: ID19 Noise
    Fellow Frogger! caparobertsan's Avatar
    May 2011
    SOUTH MORANG
    793
    Default ID19 Noise
    Hello, All
    recently, I have started notice the noise coming from motor or engine room. I can hear occasional bird chirping squeaking sound. It even happens when car is not moving. Any Idea? Thank you.
    http://soundcloud.com/user609828763/id19-copy-2
    1961 Citroen ID19(2010~), Holden Frontera(R.I.P 2002-2014), Honda Accord EURO(2006~)
    16,432
    I'd have said it's something rattling inside the car ........................ eg: something in the glovebox moving around.
    mnm
    mnm is offline
    Croak croak... mnm's Avatar
    Dec 2010
    3,231
    Slipping fan belt?
    Matthew
    May 2011
    SOUTH MORANG
    793
    mmmm I do`nt think so but I will check it.. Thanks Shane!
    May 2011
    SOUTH MORANG
    793
    Quote Originally Posted by mnm View Post
    Slipping fan belt?
    Matthew
    Hello, I have changed belt to new one and adjusted as necessary.... I checked both generator and water pump movement and they are smooth no noise coming from there.
    19,104
    Loose exhaust clamp ?
    Bowden Cable or steel pipe rattling ?
    Loose steel cover in engine bay rattling?
    Engine prop bracket rattling?
    It's seems a familiar noise but difficult to name.
    May 2011
    SOUTH MORANG
    793
    Bowden Cable or steel pipe rattling ? What is this?
    Loose steel cover in engine bay rattling? And this?
    Engine prop bracket rattling? And this?
    I will check inside again for looseness.
    Thank you
    19,104
    Quote Originally Posted by caparobertsan View Post
    Thank you
    If you draw four blanks on the descriptions.
    It's probably best to take it to a mechanic.
    Advice, by the nature of an audio file and forum posts needs to pretty general.
    May 2011
    SOUTH MORANG
    793
    Ahh thanks. I can do all the work but I do`nt know the correct name of parts.
    I will look closer.
    16,432
    try lifting the bonnet and very slowly increasing the revs.... the air pickup tubes vibrates like crazy at about 2200rpm on one of mine. It could be anything though. It sounds like something rubbing to me as apposed to something like a fanbelt.
    19,104
    I will look closer.
    In which case I probably owe you an apology. Because I took your first post the wrong way.
    Armidale
    2,354
    Still sounds like a dry bearing, or something rubbing. Does the ID19 have a cabin ventilation fan?
    Alec
    May 2011
    SOUTH MORANG
    793
    Nah it is fine! Thanks
    May 2011
    SOUTH MORANG
    793
    Alec
    No mine does not have fan to send air inside. I am hoping not baring in the engine.... Thanks
    May 2011
    SOUTH MORANG
    793
    OK I will try, very hard. If I cannot find source of noise, I just leave it till really break down permanently.
    Will fuel pump or hydraulic pump make noise like that?
    Fellow Frogger! Vincenzo's Avatar
    Aug 2014
    Auckland, NZ
    163
    I too have been trying to identify an odd noise coming from my car. Quite different to yours but in my explorations I managed to create a squeak similar to yours that occurred once I had mucked around with the headlight springs. Now they squeak in a similar way on odd occasions... I haven't tried any lube as yet, was thinking of using some of that 'dry lube' from Jaycar.
    DS23 Pallas BVM Vert Argente - in ground up restoration, soon to be BVH.
    DSpecial 4speed Beige Vanneau, previous ; XM 2.0, maroon, my first.
    And a variety of the usual crapboxes before seeing the light. Except my Mini Cooper with the 3.4 cam and twin webers - that wasn't a POS.
    Bikes -
    Ducati GTS860, CB350, XT550, Z500, T250, XR200, ag90.
