C5 handbrake problems
Results 1 to 23 of 23
Like Tree5Likes
  • 2 Post By smiffy1071
  • 1 Post By smiffy1071
  • 1 Post By The Dunk
  • 1 Post By jaahn
Thread: C5 handbrake problems
    Mar 2015
    Kingscliff NSW Australia
    61
    Default C5 handbrake problems
    My 2003 C5 handbrake will not hold the car on a hill.
    Seems to be seized in the front brake caliper. I have been told that I will have to pay for new calipers
    around $1500 in parts. Is there another way?
    Keith
    Newcastle
    2,624
    Hi Keith,
    Its been discussed before and I participated somewhat.
    Look here for ideas; 2002 C5 - Brake issues(I think)
    There has been no feedback on the outcome !! Bad AFer.
    I still have the two caliper for sale !!
    Jaahn
    Bristol/England!
    1,486
    Yup, been there done that, I had to put new calipers on the front of mine, but seriously, 1500 bucks is really taking the piss!
    Look on ebay where you can find re-manufactured units for about £40 per side. At that price, it's worth the expensive air freight!
    When you order them, they will need the 3 digit casting code, as there are 2 different sizes.
    shanadoo and addo like this.
    Mar 2015
    61
    Hi Jaahn,
    Thanks for the response of my handbrake problem.
    Do I have to look for a casting code on my calipers to check if they are identical to the pair you have for sale?
    Just checking your price and do you have any idea what weight they would be for freight / post to the Tweed coast?
    Keith
    Bristol/England!
    1,486
    Whichever casting number they are, they will physically fit, but it may be necessary to change the discs and pads.
    The difference is the distance from the hub to the outer edge of the disc.
    Mar 2015
    61
    Ok thanks for the reply. Can I see the casting number with just removing the wheel?
    Newcastle
    2,624
    Quote Originally Posted by The Dunk View Post
    Hi Jaahn,
    Keith
    Hi Keith
    I do not believe there are two different calipers on the cars sold here. Note smiffy1071 is in England and they have lots of different models there. However I could be wrong.
    However I will check the numbers. I will PM you about them. Check your PMs.
    Jaahn
    9,777
    The V6 uses a larger diameter disc compared with HDi and petrol 4, which use common front brakes. I believe the calipers differ accordingly, but you can confirm in the factory parts listings. Which engine are we talking about here?
    Bristol/England!
    1,486
    I don't think they differ according to model, I reckon it was more like what they had in the parts bin at the time.
    When I ordered a pair of discs, they arrived and looked identical so I fitted them and only then did I learn the difference.
    My car is a 2.0 16v hdi and uses the larger size. Yes you should be able to see casting numbers by removing the wheel, but
    You may need to wire brush the dust off.
    addo likes this.
    Bristol/England!
    1,486
    Just been reading up, some cars have 283mm disc, some like mine have 288mm disc,
    and there is also a 304mm size, which I assume is for the v6 model
    9,777
    I've never checked for S2 / facelift models like yours, but do have a recollection that it did change for the HDi. I did look it up for the S1 C5 variants sold here and the V6 is 288x28mm vs 283x26mm for the others. Citroen Service usually gives dimensions as well as the part numbers. If you just choose C5 II and do not select a model variant on the main page, then it returns all the possible fiche variations listed by model.
    For reference, here's Jaahn's old advert with pictures:
    Citroen c5 (+ peugeot) discs, calipers, hubs, carriers. Cheap
    Mar 2015
    61
    Hi David,
    Thanks for the advice. My car is a 2 lt petrol 16v estate.
    cheers Keith
    Newcastle
    2,624
    Keith the numbers cast on are 0204yo, 1083 and 0202yo, 1084
    the numbers on a paper bar code are, 9646601580 and 9646601480. Hard to see a bit.
    Did you see my PM. Aware of PMs ?
    Jaahn
    Mar 2015
    61
    Hi jaahn,
    Just removed the wheel and yes my numbers cast on are 0204Y0, 1083.
    the numbers on the paper sticker are unreadable after tried to clean dirt off.
    Keith
    Mar 2015
    61
    Sorry no I`m not aware of PMs
    Newcastle
    2,624
    PM stands for private message. Go to the top of the page and click on Notifications(beside your greeting from AFs) then inbox. Should be something there. I asked you to email me direct to my email. Please do this as I will be travelling and may be only checking emails.
    Jaahn
    Fellow Frogger! Clogzz's Avatar
    Mar 2005
    Sydney 2087
    189
    The handbrake return spring pivots need lubricating:
    French Car Forum ? View topic - c5 handbrake
    2003 C5 2.0i AL4 205,000 km 76372389
    16,428
    CX owners just learn to live by selecting there parking spaces so as not to rely on the handbrake..... That way the car is generally where you left it when you return....................... Hey it works for me
    Mar 2005
    Sydney 2087
    189
    ... selecting their parking spaces so as not to rely on the handbrake ...
    Well, I came to the land of wide open spaces; and here's where I finished up.
    16,428
    Quote Originally Posted by Clogzz View Post
    Easy ... I'd have the CX parked in the shed .... or on the grass there .... see the grass isn't down hill right And it'll keep the oils stains off the drive to!
    Armidale
    2,352
    Well Australia is mostly flat....
    but hardly anybody wants to live in the flat bits .
    Alec
    Mar 2015
    61
    Hi Clogzz,
    Thanks to your post re "handbrake pivots need lubricating" I have been able to free up my return springs and pivots
    saving me heaps of money and worry.
    I sprayed "INOX" each day over 3 days then went to work on them as described in your post.
    Didn`t take long at all to free up passenger side then drivers side a bit more effort was needed but a few taps
    backward and forward success. What a great feeling it is to have a handbrake that works after ages.
    A big thanks to all fellow Frogers for your input
    Clogzz likes this.
    Newcastle
    2,624
    Keith
    Hi Clogzz,
    Thanks to your post re "handbrake pivots need lubricating" I have been able to free up my return springs and pivots saving me heaps of money and worry.I sprayed "INOX" each day over 3 days then went to work on them as described in your post.Didn`t take long at all to free up passenger side then drivers side a bit more effort was needed but a few taps backward and forward success. What a great feeling it is to have a handbrake that works after ages.
    Hi
    Yes there is another way ! Keith I think you put the lie to a lot of Nay-Sayers on here who think the calipers can only be canned and new ones put on at some large expense Just a rusty mess or worse I think I heard !!
    However i would still recommend that you strip and clean and lube for the long run. Give'm a 12 year surprise present ! They will probably see you out then.
    Jaahn
    The Dunk likes this.
