C5 X7 rear tyre wear
Results 1 to 17 of 17
Like Tree2Likes
  • 1 Post By 4cvg
  • 1 Post By 4cvg
Thread: C5 X7 rear tyre wear
    Citroėn Tragic UFO's Avatar
    9,721
    Default C5 X7 rear tyre wear
    My C5 is approaching 150k km and still running fine, except for the way it wears rear tyres. I'm wondering if others have experienced similar and if so how did you rectify it.
    Most of the distance the car travels is on highways and usually with light load.
    The front tyres wear fine - even tread wear. All tyres run at 35psi and are checked regularly.
    The rears wear the inside edge well before the outside edge is (seemingly) even much past halfway.
    Any worthwhile ideas please?
    9,774
    Rotate! The front will scrub the outside edge off, leaving you with a beautiful, evenly worn tyre.
    I guess you could check the alignment and for sloppy bushes at the rear if you think this wear pattern is something that has changed over time.
    8,763
    Rotate! And listen to the music from the pressure sensors.........
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    Rotate, but rotate regularly. i.e. Rotate, rotate every 10k, of course always on the same side but I am sure you know that. However there maybe something worn in the rear suspension, who knows. I think the only way to know for sure is take it to someone with a good alignment gauge and see if all factors are within spec.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    9,721
    Alright - but I hate rotating tyres. Better learn to love it again.
    It's getting a new pair prior to Cit In.
    Thanks for all your advice.
    May 2012
    83
    what variety might you be using ? Last set on my C5 was Continental .....thought they were good, and at about $50 a Tyre cheaper than Michelin ...that makes them even better. See you in Nuriootpa.
    9,721
    I run Kumhos at present and have been very pleased with them. Quieter than the original Michelins and wear better than the Bridgestones I had on. Come in around $245 each I think.
    Armidale
    2,346
    Our 307 did the same thing from new...
    Alec
    Oct 2003
    1,304
    I hate rotating tyres as well. Only gets done on the Prius as it is part of the service. I swapped tyres on our Xantia to get a bit more out of the set and to compensate for different wear patterns. Lasted 2 days, the noise was unbearable.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    con
    con is offline
    sydney, nsw, australia
    505
    Craig,
    which Kuhmos? I need to get a set for my C5
    thanks
    con...
    9,721
    I'll try to remember to look tomorrow and let you know.
    Feb 2005
    rosevale/tasmania
    2,755
    If they're wearing the inside edge then (assuming that they don't have -ve camber) they're toeing out & the cause of that (if the C5 can be 4 wheel aligned & has had that done - to no avail) is that something is bent or, more likely, the locating bushes are worn & allowing the undriven rear wheels to drag back into toeout. 150k kilometres is rather premature wear but...
    Solution: rebush.
    Rotating is always wise for three reasons:
    One's to even wear (as others have noted).
    Another is to ensure that the least wearing tyres (usually the rears on a FWD car) don't continue to be used past a sensible tyre age.
    The last (related to the second) is so that tyres can be replaced in optimal sets of four having all worn out at the same time.
    cheers! Peter
    addo likes this.
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,927
    Hi Craig,
    My C5X7 is at 110kkm and rear tyres (2nd set) look to be wearing evenly. I would also suggest your car must have gone into toe-out on the rear but I see Peter has beaten me to it.
    Here follows a Google translate of the rear suspension chart in the 2008 C5X7 Mechanics Handbook
    445
    VALUES CONTROL AND ADJUSTMENT AXLE GEOMETRY
    Train "REAR"
    Rear axle suspension "Hydraulics"
    Control values
    Tires 225/60 R16-225 / 55 R17-245 / 45 R18-245 / 40 R19
    All Types engines
    Tracking, Adjustable, 0 ° 34 '± 0 ° 09'
    Camber, not adjustable, - 1 ° 16 '± 0 ° 30'
    Pushed angle, not adjustable, 0 ° ± 0 ° 30 '
    Asymmetry camber: ± 0 ° 30 '
    So perhaps it needs its tracking adjusted.
    Cheers and looking forward to catching up in Nuriootpa.
    Ken W
    9,721
    Quote Originally Posted by con View Post
    Craig,
    thanks
    con...
    Finally got around to checking - sorry for the delay.
    Kumho Ecsta LX Platinum 245/45 ZR18 100W
    con
    con is offline
    505
    Thank you Craig,
    much obliged for the for the information.
    Feb 2005
    rosevale/tasmania
    2,755
    Thank you Craig,
    I'm not sure what criteria you wish your tyres to satisfy but be warned that the LX KU27 is a long wear, low noise, high comfort specification. (And Craig singles out wear and quietness as merits.) The "flip side" of that is normally soggy handling response & low wet-grip. You might not much care but if you do prioritise a taut handling tyre with good wet grip, then a wonderful set of options is available in 245/45-18.
    Top specification sports tyres like the Pilot Super Sport & P Zero perhaps won't suit something like the C5 but what of Conti's not overly harsh SportContact 5 or Michelin's PS3? Or, given that a "4 for the price of 3" deal is current for Bridgestones at the moment (expires end of April) how about the just released Adrenalin RE003 (which sounds very good)? Or Dunlop's Sport Maxx RT or Goodyear's Eagle F1 Asymmetric 2? Or, a step down from all of the above but a step or three up from the KU27, Pirelli's Cinturato P7?
    Anyone using this size is blessed with good choices. Personally, I'd take advantage of the deal & get the RE003.
    cheers! Peter
    con likes this.
    con
    con is offline
    505
    thanks for the comments, Peter. I need to decide whether comfort or handling is more suited to my needs.
    cheers
