xm ignition module
Results 1 to 17 of 17
Like Tree3Likes
  • 1 Post By SLC206
  • 2 Post By David S
Thread: xm ignition module
    Fellow Frogger! denxm's Avatar
    uki aust
    449
    Default xm ignition module
    My xm ignition module has called it a day in Finley,just north of the Vic border.
    Drove all the way from the qld gulf, pulled in at DS motors to get spheres checked then would not restart after re fueling at Finley on my way to melb.
    it is a bosch mtro3 0227100124
    Who would be the best parts business in melb or sydney to ring first thing on sat morn to get them to put it on a courier to Finley..thanks
    Don't remind me!
    16,609
    I have a spare one which could be express posted Monday; can't see you getting one any faster. Send it back when you're fixed up.
    Got a line of cheap units from OS, can't get you one fast enough though.
    Can't find a Camira or Pug from late 505 to 405/205 being wrecked anywhere about?
    uki aust
    449
    Thanks ADDO,will get back to you if i do not have luck ringing around sat morn, asked some local petrol heads here if they knew of any
    of those wrecks around,but it is all 4x4 or jap or koreon plus plenty of tractors
    Sep 2003
    North Parramatta
    3,997
    We found one at Repco in Moe a few years ago while on the road - as addo said the humble Camira uses the same device.
    Oddly enough the XM was listed in the Bosch parts book at the parts counter.
    UFO likes this.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    con
    con is offline
    sydney, nsw, australia
    505
    Quote Originally Posted by denxm View Post
    The 0 227 100 124 - is also known as a BIM 027. (Just to confuse the plebs - would have been simpler to call it a BIM 024!!).
    A direct equivalent ls the Bosch 9 222 067 027 module.
    According to some sources, these are the same modules:
    Bosch 1 227 010 003
    1 227 010 005
    1 227 010 006
    1 227 010 039
    Citroen 96 048 070 80
    GM 90006499
    Lucas DAB 405
    Magneti-Marelli 940 038 508
    Opel 1208243
    SAAB 750 3600
    Volvo 1 332 584
    Good luck.
    uki aust
    449
    CON,Thanks for the extra numbers , will hit the phone at opening hour on sat,maybe lucky at bigger towns nearby.
    con
    con is offline
    505
    Quote Originally Posted by SLC206 View Post
    ..... addo said the humble Camira uses the same device.....
    That would be the JD Camira (1.8L) from 11/1985 to 01/1986 (only).
    Hopefully the problem has been solved, by now. If not, the wreckers maybe your best bet.
    The Bosch catalogue quotes BIM 027 was used in:
    - Peugeot 605 (UFZ) from 07/1993 to 05/1999
    - SAAB 900 from 09/1985 to 07/1987 and from 09/1991 to 08/1993
    - SAAB 9000 from 08/1986 to 08/1993
    - Porsche 911 Carrera 964 from 09/1989 to 08/1993
    - Porsche 928 (4.7L) from 08/1983 to 07/1986
    - Porsche 928 (5.0L) from 08/1985 to 07/1986
    - Porsche 928 (5.4L) from 08/1991 to 11/1995
    - Porsche 944 from 11/1988 to 07/1991
    CitroŽn Tragic UFO's Avatar
    9,721
    I replaced one in mine years ago with a Tridon brand from REPCO. Worked fine. Usual cause of failure is the gradual degradation of the thermal paste on the backing to the heat sink. As SLC206 said, ask for one for a Camira.
    Don't remind me!
    16,609
    I suspect a lot of other modules can be made to work, it only uses four of the pins. Scotchloks might see you going at a pinch, with an XF Falcon module and the connector "tails" off a wreck.
    Pin 5 - ECU trigger
    Pin 4 - switched positive (also to coil)
    Pin 2 - ground
    Pin 1 - to coil, other terminal
    Cases normally need grounding as well.
    9,721
    Found my old thread from 2005, the part was A TRIDON Ignition Module, p/n TIM006
    Don't remind me!
    16,609
    denxm - the Express Post package is at Finley Post Orifice awaiting your return...
    uki aust
    449
    To add to con's list, i picked up fuel miser cm742 module from repco
    got to head to ballarat area for a day or two, hope i don't have to pack the thongs and wear socks.
    thanks to addo for sending a module though by luck i did not need it.
    Don't remind me!
    16,609
    There was also a virginal tube of silver heat paste in there, too. Good gear, that stuff.
    Fingers backed up my idea the XF Furd one would probably get you out of jail.
    12,256
    said XM was spotted parked outside a pet shop in parkes on wednesday morning
    1 x '98 306 GTi6
    16,421
    Dark grey XM ? I saw one drive up and down our street last weekend
    9,774
    Quote Originally Posted by pugrambo View Post
    So ... gone to the dogs and now searching for its final resting place.
    addo and UFO like this.
    uki aust
    449
    No no no, it was not looking for that,was just quality and style having a breather before the big run home,
    got a shock when friendly frogger came to the window,was nice to have a chat to pugrambo.
    also for double chevon, i had stopped in buninyong to get a bite to eat when a local young guy said there is a guy with citroens parked in his front yard up the road but i must of not been observant enough , a pity for i was watching the gps a bit too much working out the route
    then headed to ballarat to look at the begonias.
    even with the break down was a good trip and saw some nice country.
