C 4 battery problem
Results 1 to 15 of 15
Like Tree5Likes
  • 1 Post By Hotrodelectric
  • 1 Post By andy bram
  • 1 Post By seasink
  • 2 Post By robmac
Thread: C 4 battery problem
    don
    don is offline
    Fellow Frogger! don's Avatar
    Mayfield Newcastle
    436
    Default C 4 battery problem
    Hi all
    Had my C4 hold up in our winery building for the last 2 weeks and haven't driven it.
    On Tuesday I started the car and moved it outside ready to leave for home in Newcastle.
    Packed up ready to go and Citroen NO GO.
    With all the bells and whistles and diagnostic abilities, features built into these cars wouldn't it be great to know that the battery has a bad cell and is about to fail.
    Any way for the record - turn key solenoid kicks and releases dashes all go blank and lots of little clicks from under the dash and engine bay ( the sound of dyeing flamenco dancers I would guess ).
    Turn on lights hit starter, No lights No dash more dyeing flamenco dancers clicking, Pretty obvious battery problem.
    Connect alternate flamenco dancer energy source and hay presto instant Russian ballet including full symphony orchestra on 106 .1 ABC FM. But Citroen now has hangover and cant remember what day it is and wishes to speak in tongues. So reset the vehicle configuration, and gave the flamenco dancers their matching orders to the sound of the brass band TU5JP4 ( not available on EMI label)
    Accelerate to drive away at low rpm and the conductor says STOP the bus with the usual beeps, lights and whistles. Rev a little more and drive home with bad battery cell. Got home turned off ignition and tried to start with the same surround sound experience as 1 hour before.
    Next day trip to auto store for new battery $175 a century unit, and all is well.
    The replaced battery was fitted in 2010 after failing a load test so I guess its about time.
    We really haven't progressed that far with automotive electronics just made it harder to self diagnose.
    19,092
    Next you will be asking for a car that runs without fuel.
    The "clicking" starter solenoid is the dead give away it's a battery. It's been a classic sign since time immemorial.
    If you ain't got power nothing can work.
    don
    don is offline
    Mayfield Newcastle
    436
    not the solenoid that clicked bur every other relay or electrical device with contacts
    NOT QUITE as simple as the pictured 404 device
    which is my point !!!!!!!!!!
    and to note
    I did the arc test on poles after removing the battery and it didn't have a single Volt. Totally inert
    In All my years of electrics Ive never seen a battery go from tired to dead so quick
    CitroŽn Tragic UFO's Avatar
    9,721
    My XM once lit up like a Xmas tree with castanets as the battery failed. Very exciting while sitting at traffic lights.
    San Diego, California, USA
    3,534
    Jeeze Craig, you say that and I get this vision of Carmen Miranda.
    addo likes this.
    Coffs Harbour, NSW, Australia
    616
    Hey Hotrod, these young bloods wouldn't have a clue who Carmen Miranda was, or her fruity attire.
    don
    don is offline
    Mayfield Newcastle
    436
    And yes robmac the french car that runs without fuel would be very beneficial to the environment around my wallet.
    But I would still need some volts stored in a black plastic box so carmen miranda can do her thing every 5 years or so.
    3,534
    Quote Originally Posted by citroenut View Post
    Well, the title on my avatar does say "old fart apprentice". But you referenced it, so that's close enough.
    Don't remind me!
    16,609
    Icon12 Gatinhos Brasilieros
    You've now given me a "Desafinado" earworm.
    May 2012
    burnie tasmania
    14
    check the output voltage of the alternator if it is high it will kill a battery very quick and mess up dash lights and guages have found this several times in the past
    Hotrodelectric likes this.
    8,763
    Just for Addo
    addo likes this.
    19,092
    In electronics it a variation of "race" condition. ie Two functions compete with each other to perform.
    The number of devices doesn't matter it's the symptom that gives away what is going on.
    The sequence of events is this:
    1) The battery voltage is low.
    2) You turn on the ignition and the relays associated with the BSI computer are powered albeit at reduced voltage. They energize.
    3) You turn to the crank position which powers the starter.
    4) The extra load causes the battery voltage to fall below the hold-in voltage of the relays and possibly the solenoid.
    5) The relays release causing the clicking noise
    6) The battery voltage increases because the load is removed.
    7) If you continue to hold the key in the "start" position the sequence 3, 4,5 & 6 will continue until the battery is absolutely discharged and then nothing will happen at all.
    If you think about it, it situation is very similar to seeing the interior light on the 404 dim and solenoid rattle when you try to crank your 404 with a crook battery.
    But because there is BSI computer and a heap of relays the relays click instead of the light dimming.
    I'm not trying to be prickkie, I'm trying to explain the reason for sequence of events you observed.
    3,534
    I do what I can.
    3,534
    Quote Originally Posted by andy bram View Post
    Excellent point, too easy to check.
    10,797
    Quote Originally Posted by don View Post
    and to note
    Back in November our Scenic went from start first turn to nothing from one start to the next try only ten minutes later. Our 306 did it while parked for an hour once.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
