XM (Zantia maybe?) Blinker stalk
Results 1 to 7 of 7
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Default XM (Zantia maybe?) Blinker stalk
    Hi,
    I thought I had a spare but it is off an earlier model. Has any one got a blinker stalk that has the horn and headlight control on it - mine has melted.
    thanks
    Warren
    16,421
    Let me guess... it still "sort of" works but you have to hold it on ...? It can be repaired quite easily ... pop it apart and take a look. I think and had both a Xantia and an XM one do the smoke trick. It's a quick simple fix with a smear of araldite.
    Shaen L.
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Um - just bought a new one from eBay - I will check with you before I do anything else.....
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    PS - mine doesn't move at all so, I hope other drivers can remember the old hand signals (they probably don't teach them anymore)
    16,421
    It'll probably still work in one direction ... or hold it in the direction you want. being a late 24valve XM possibly it's different. It sounds like the same problem though
    found a piccie ... .see the plastic bit in the middle of the contact strip. This is what melted/smoked. As it now has a melted bit the slide contact jamns in it and the lever will no longer move. All you do is dob some araldite there to build up the plastic bit shown, and it'll be better than new.
    Fellow Frogger! denxm's Avatar
    uki aust
    449
    As Shane says, a bit of araldite to build up the plastic part.
    Did it to my xm years ago when the switch was sticking a bit, never missed a beat since
    Don't remind me!
    16,609
    I've seen some stalks physically worn out in the brass bits, hopefully the part I referred our man to is the correct one.
