Ds 21 bvh
Results 1 to 7 of 7
Thread: Ds 21 bvh
    Kapunda
    457
    Icon7 Ds 21 bvh
    A friend of mine took me for drive in his yesterday as he was very concerned about some strange noises.
    Every time he changed gear it made a loud squeak which lasted for about 1/2 sec,quite disconcerting.Of course this doesn,t happen when the car is stationary! Any clues out there?
    Woody
    Los Angeles, CA USA
    1,955
    Radiator stay is snug?
    Brake disc touching the sheet metal duct?
    BVH needs to be bled?
    Kapunda
    457
    Have bled the Centrifugal Reg, -no change
    Woody
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,345
    Does the noise happen immediately upon movement of the BVH lever, or half a second or so later? The reason I ask is that my DS19 makes a noise like that but not very loud. It happens about half a second after I move the lever and I think it is caused by the action of the synchro delay pistons in the BVH control valve. Rather than worry about it I listen for it and celebrate it because it mean the next gear has been engaged.
    Roger
    May 2013
    Pennsylvania USA
    24
    Mine does the same thing occasionally with the 1-2 shift. Also, sometimes the effort for the 1-2 shift is a more than normal.
    I spoke to to a long time Citroen mechanic and he said both are fairly common and not a concern.
    Both only happen on the 1-2 upshift. I'm curious what others have experienced.
    Paul
    1969 DS21 Pallas BVH
    Others:
    1966 International 1000A Pickup
    1963 VW 1200
    Fellow Frogger! Middlemoon.1's Avatar
    Jan 2011
    Alphington
    845
    Mine had that for a few days, but it disappeared. Quite quiet now. We did a bleed. That might have helped.
    Tim
    Member cactus61's Avatar
    Perth
    112
    in my bvh if the LHM level starts to drop a little low, the first thing that is noticed is it starts to clunk when I change gear. I can't recall if any difference when stopped or not but checking the fluid level on maximum height adjustment would be my first check (and easiest fix!)
    1974 DS23 'Borg'
