C5 or Peugeot 407 tow bar
Results 1 to 17 of 17
  • 1 Post By jaahn
Thread: C5 or Peugeot 407 tow bar
    Melbourne, Victoria.
    1,390
    Default C5 or Peugeot 407 tow bar
    Hey Froggies,
    does anyone know if the towbar for a C5 would be the same part and therefore compatible with a Peugeot 407 ? Would the wiring also be compatible?
    Cheers...
    2004 C5 V6
    previous.... 1996 Xantia VSX Auto.
    1978 CX C-matic
    1968 DS Hydraulique Semi Auto DS 21.
    Sep 2013
    Elphinstone Victoria
    537
    Quote Originally Posted by George 1/8th View Post
    Hey Froggies,
    Cheers...
    2004 C5 V6
    1978 CX C-matic
    If you're looking for someone with a C5 towbar fitted, I'm your man. (2002 Hdi) Just let me know what details you need, or photos and I'll post.
    10,094
    I think a lot of the C5 towbars were locally made, so may differ to what Pug used - different importers at that point. There are also slight differences between sedan and wagons and also between S1 and 2 versions. Later cars had a deeper rear bar, so the towbars differ for at least that reason.
    Dec 2010
    225
    the electronics for tow bars are different on these models not conpatable as c5 were using bypass wiring
    1,390
    Quote Originally Posted by ScotFrog View Post
    Hi ScottFrog, was your towbar on the car when you bought it or did you have it fitted? Is it locally made or a French one? Was it expensive?
    Are you keeping it?
    What type of wiring socket is it, and there seems to be some very special and very expensive wiring issue that is involved with a C5, apparently you cannot just hook up wires like you could on any 'normal' car.
    Any ideas would be helpful.
    cheers...
    1,390
    Thanks David.... this could be a pretty rare beast to find...
    1,390
    Quote Originally Posted by niks View Post
    I'm thinking it would be to switch off the reversing sensor...that's all I can think as to why there has to be some special set up worth $300.00.
    9,331
    Not a C5, but take a peek at 307 - Tow Bar - powered for brakes/indicators etc for a method with very low current relays. You can buy a ready-made in the UK.
    Sep 2013
    537
    Are you keeping it?
    cheers...
    I bought the car in Queensland (Apples for apples they appeared to be $1500 less than identical Victorian cars) and it gave me an opportunity to get up to a little mayhem with my brother.
    It was a Toowoomba car and very well fitted out including towbar which looks to be genuine Citroen. Pic 1.
    The wiring socket is a Narva and I had to browse a Repco store to find an adapter (2nd picture) The sales guy said 'no chance mate!' and was a bit miffed when I found it under his nose. About $25.00 from memory. Electrics work OK.
    I can measure if you want details but you're in Melbourne like me. Send me a PM if it's easier to catch up and grovel under the car.C5 or Peugeot 407 tow bar-20150219_cittow-.jpgC5 or Peugeot 407 tow bar-20150219_cittow-b.jpg
    SF
    1,390
    Thanks SF... good info. I might make contact and have a look underneath....grovel grovel...ha ha... thanks.
    Your bumper has the socket on it . so the proper tech wiring is already there....
    I will have to keep checking the Wreckers till I find one...
    cheers..
    Newcastle
    2,756
    Default Tow bars and wires !!
    Hi George 1/8th
    I made a towbar up for mine. I used a Triton bar, from memory, and modified the end plates to suit some custom ones. Not rocket science really. I have done a couple before. I had a car trailer and a caravan so they towed them OK over the years without a problem. I cut the bumper plastic to get a neat hole and no loss of clearance.
    For the wiring I trawled the UK ebay and purchased a genuine C5 kit for a very modest amount delivered. It is surprising what is available over there as these cars are now obselete there
    However there are non genuine wiring kits to suit can bus cars from towbar suppliers in England. They are readily available there as opposed to a complete lack of information about them here. We seem to have a lot of dic* heads here supplying towbars here. There are technical reasons to need a kit that I could detail but am in a hurry now. SHMBO has frowned.
    Cheers Jaahn
    16,698
    Look on ebay UK. shop around all the sellers for the best postage amount. The wiring bypass kit is quite cheap.
    1,390
    Thanks Jaahn, thanks Shane...
    Don't remind me!
    16,609
    The main issues to look at are chopping the rear fogs when a trailer is plugged in, and disabling the reverse sensors similarly. If you ignore both these then solid state relays should do the trick. There will be one or two wires from the maxi fuse box (not live, yet) that can be picked up in the tail harness to feed power to the switched side of your relays.
    The most elegant harnesses are the genuine, but they seem to be often €100 upwards, plus post in France.
    Newcastle
    2,756
    Hi
    I think addo is understating the need for a set of relays to run the trailer wiring. The C5 and also other modern cars monitor the current to almost everything, so if you put another bulb in the circuits of the lights it detects a fault. So that means lots of faults as you drive. Also there may be other things to turn off when you connect as said.
    When I fitted my genuine harness all wires were there in the back to operate it. The bus wires and the power for the unit. The activation for the trailer lights had a female/male connectors to sense the car lights on each side from the original light connectors. I replaced the original French trailer sockets with an Australian type also. It had a switch to tell when the trailer was plugged in to turn the system on.
    Jaahn
    addo likes this.
    1,390
    Thanks Jaahn,
    I would have thought the switch would have been to turn off the reversing sensor when the trailer is connected.
    cheers..
    Don't remind me!
    16,609
    I think the reverse sensors are either disabled by a CAN signal or a spoofed return. If you simply chop the sensor line with a mechanical switch or solid state relay it will display faults on your central display and log them.
    Look for the best price on 9428.76 if your ORGA number is 10173 or below.
